Virtual replication of RomeroUK motor/generator by 3D FEM modeling
Started by teslaalset, June 06, 2011, 02:10:21 PM
wings
[quote author=teslaalset link=topic=10841.msg289888#msg289888 date=1307431511
I can generate AVI files too, but they are much larger than the animated GIF.
I will post an AVI later this week.
Round trip is simple, this only requires 22.5 degrees of simulaton and then loop it.
I'll post it.
[/quote]
22.5 = 360/8/2 larger than 20 = 360/9/2 , this mean that you find symmetric effect in the coil? there is no type of hysteresis
teslaalset
Quote from: wings on June 07, 2011, 04:55:38 AM
You are partly right, Wings.
It depends on what coil you watch the details.
If I zoom into a coil where the rotor magnet position is started 11.25 degrees before the intended stator coil and then simulate a rotation stroke of 22.5 degrees, it will give sufficient info to represent reproducable fllux variations.
wings
Quote from: teslaalset on June 07, 2011, 05:07:49 AM
If I zoom into a coil where the rotor magnet position is started 11.25 degrees before the intended stator coil and then simulate a rotation stroke of 22.5 degrees, it will give sufficient info to represent reproducible flux variations.
I see ... the hysteresis of B-H curves
interesting;
the simulation can be useful to see the electromagnetic interaction, how you can see the electronic part like current, voltage with high capacitance?
EMdevices
@ teslaalset
I'm studying your model and the results, as we speak, and I'll comment more intelligently shortly,  but thank you for doing these simulations and models, they look great!.
EM
PS.   Ok, here's some questions teslaalset,
How do you derive the force that you plot?   Do you first use the calculator inside Maxwell to sum up the surface forces vectoraly, and then take this resultant vector and do a dot product with a unit vector in the direction of the motion?  this is how it should be done from what I remember.
also, it would be nice to produce a smoother force profile, and I would expect it from the software as this is a very simple model.  So I'm wondering how you actualy modeled the coil?  And I mean the coil not the ferrite core?
And most importantly, make sure you use the SAME mesh for all the 3 different scenarios,  and use a highest fidelity mesh generated with the closest gap and the magnet at TDC, and make sure you tell the mesher to use symetry, as the mesh will not always be symetric just because your model is symetric.   Symetry of the mesh, about the TDC line, is very important in this setup as we are trying to look for an inbalance in the forces.
Anyway, give those comments some thought.    Good work!
teslaalset
Quote from: wings on June 07, 2011, 10:12:39 AM
interesting;
@Wings,
I am not sure I understand your remark on B-H curves.
What I see is that in the example of a single coil / two magnets the magnet passes by, starting from left, to TDC, then to right, so currents in the coil will make a positive and negative swing.
Regarding the electrical part, Maxwell can inmport electrical circuits. In this case a simple one that romeroUK uses, kind of. Currents and voltages can be monitored by placing meters in the circuit, like I did in the above example.
