Safe One Wire energy transfer by Serbian inventor Milutin Miletic
Started by hartiberlin, June 16, 2011, 11:51:28 AM
tadejstenta
Quote from: FatBird on June 19, 2011, 09:06:52 PM
Thank you for the Translation.  I have a question please.
In the line below, is the word  ahmmmm  meant to be Aluminum?
0:40- 0:46
this one uninsulated wire contains ahmmmm conduct all three: zero, phase and earth
Translation is from that video:
http://www.youtube.com/watch?v=eJhZBWKFon4&NR=1
ahmmmmm means  a mistake in his speech.
forest
Quote from: SchubertReijiMaigo on June 20, 2011, 03:03:42 AM
Did you mean pulsed DC instead sine AC ?
Curious because in pulsed DC you have some eddy and hysteresis losses too...
Yeah, I know that Tesla used pulsed DC to obtain Radiant effect...
So where is the OU even with pulsed DC, sorry but in this invention I don't see OU, bust a different (and safely) way to transmitt energy over long distance with little losses, the application can be power line, instead flowing 400 KVolts at 1000 amps, you just flipping small magnetic dipole in a steel wire over thousands kilometers...
Pardon but OU is just that - amplification of efect of small energy.No magical creation of energy.
Law of conservation of energy is not violated, we are just doing much more work using tiny initial energy.
"2:35-2:52
It uses 40-50 wats instead of more kilowatts in owen (boiler) for heating water. Temperature is adjusted as desired. Here is adjusted at around 40 degrees. When we release the current all this is (?thermo something?) and it slowly growing."
ElectricGoose
Yes....that's what I said.  PULSES and that AC is useless (in two regards).
1)  You want to 'bang' that iron (steel) like you are swinging a hammer against it...sharp blows on and off.  Sidepoint - Did you realise that if you physically swing a hammer at iron whilst a coil is positioned around the iron, you will produce good current/voltage!
2)  AC is the incorrect waveform AND it creates friction back and forth.
Start experimenting.
grizli
Quote from: romerouk on June 17, 2011, 09:52:05 AM
NETIKS, why do minimise something that looks simple but can have a high impact?
If you folow the cables comming from the power socket u can see that we don't have any complex circuit, nothing to convert to high voltage then convert it back, no AV plug, there is no space enough for anything like that.
In my opinion we only have capacitors and a small coil and no special conductor, just steel wire.
I am planing to investigate and try to replicate this one, for me this is a great discovery.
Romero
Wire may be ferromagnetic ?
In video he mentions special wire compound , hmm
grizli
Quote from: hartiberlin on June 19, 2011, 09:47:55 AM
Hi Pese,
yes,the Avramenko plug is not OU, but you can transfer also a lot of energy via this way over one
wire. I have seen a picture where he lighted up a 1 KW Bulb with it with just a small single wire transfer.
You only need the right fast diodes and a good foil capacitor at the receiver.
But the Miletic invention seems to be just magnetic as explained above.
P.S. By the way,
I wonder if the circuit Fig. 14 in
http://amasci.com/elect/mcoils.html
is the trick to the Kapanadze device ?
As you make the iron core into a coil  there you amplify the A-Field and if you put a big sized
output wire there through it  as Kapanadze does, he gets huge currents out of it.
So maybe the real part of the Kapanadze circuit is such an A-Field amplifier iron
coil just powered by a sparkgap high voltage power supply ?
So maybe his few turns of big sizedwire on his coil is just isolated iron wire ?
( sorry this is of course offtopic over here)
Where is the transformer ?
do you see how small is  "device" where is wire attached to
any classical feromagnet would require high frequency for such small "tranformer core like wire"
and there is no space for eletronics
