Safe One Wire energy transfer by Serbian inventor Milutin Miletic
Started by hartiberlin, June 16, 2011, 11:51:28 AM
hartiberlin
The question is,
if he is doing the same as the Avramenko plug ?
See:
http://jnaudin.free.fr/avramenko/avramenk.htm
There you can see Avramenko touch also the line
without getting shocked...
But this is normal, when he uses a few Mhz radio frequency,
so the waves just go on the surface of the skin, so not flowing through your body
and will not shock you.
stprue
This shouldnt be too hard to figure out giver the size of his configuration.  I like the AV plug idea Stephan, this could be it.  I was also thinking along the lines of some sort of low voltage hairpin type set up but who knows.  Time to test after someone translates, I guess.
ElectricGoose
All you have to do is use powers of deduction and Ockhams razor....eliminate what it is definitely NOT and you are left what it most surely IS.
If you have enough accumulated knowledge in alternate energy this is simple enough to link the pieces.  I have posted a english translation of the Serbian article at the Kapanadze site.  The old guy is NOT giving away any secrets but as usual, inventors can't help themselves and drop a few tidbits....the rest is elementary my dear Leedskalnin/Tesla.
1)  StPrue suggested "low voltage hairpin".  This is of course wrong.  Hairpin requires HIGH voltage to work.
2)  Inventor has created 'special wire' that "does not allow electrons to escape".  This is actually a baloney statement intented to mislead because he is NOT running standard electrical current through the wire!  More on that later.
3)  This is NOT a avaramenko plug otherwise he a) wouldnt be able to patent and b) although still single wire, you would get zapped by the pulses!
4)  Therefore....he is using something other than electrical current that likes a 'non standard' wire....let us think...what could that be??  This is a man of very little means therefore it is not going to be exotic.
5)  It is based on Tesla
6)  Size of the 'rectifier' boxes from outlet to other end are VERY SMALL....this means it is unlikely there will be masses of coils or complicated circuits (this narrows the field immensely)
7)  He states that much HIGHER current can be conveyed through much smaller diameter wire.....here again, this shows this is NOT conventional current and the wire IS different.
8)  So lets focus on the wire...and everything else will fall into place....what wire MATERIAL can be made really small and allow higher current?  Answer = Steel
NOW forget about standard electrical current because of steels high resistance AND the fact that the inventor touches the wire without getting zapped!!  Oh my...what about MAGNETIC CURRENT??  Harmless to touch and can be rectified back into standard electricity but is conveyed on a STEEL BASED wire.
All the ducks suddenly line up -
  Tesla and Leedskalnin made discoveries regarding magnetic current that would "change the world".  We know Leedskalnins perpetual motion holder is basically a room temperature super conductor and once you know its lovely workings you can efficiently push 'standard' current into magnetic current back to standard current with virtually no loss.
That is all
forest
Quote from: ElectricGoose on June 16, 2011, 09:27:50 PM
That is all
Actually I saw translation of some document and he said it's high voltage. I think it is clever harpin circuit and the output is magnetic current (higher frequency then harpin with spark gap)
