Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
madsatbg
Hello,
Today I made detailed measurements before and after, molding / "chаrge" / of quartz.
Measurements I made them in and out of the house.
The results are very interesting.
I used neon transformer 3000 v 32 kHz.
energia9
Quote from: Trawoeger on July 19, 2011, 10:45:41 AM
@energia9: Yes I know peter markovich´s work in 1977, and it was one of my basic Motors in building Pyramids.
But after a few years, i found some proof, that he was cheating the people.
On the end, he got a few mV, but he sold a few watts....
But the basic way of markovich was understandable, and some of his files are classified till today.
Second Point: It´s still not useful to discuss about AC and DC and some other points of physics.
We can speak about this, if we have the first running V´s.
And if you want to get a running V , it´s absolutely easy to follow my hints. (We do not have any time to change the Setup BEFORE we have a running V.)
The 87 Turns will be the best Setup while starting a Project. (It is easyer to calibrate)
If you have more experience, you can play with the turns, and make your own experience.
But now in this point, we have to construct the basic setup, and the only focus would be to get this thing running the next days...
ng, Tom
Thomas, because i dont have quartz sand and i cant find pure quartz sand anywhere,  i thought of smashing quartz crystals to make powder ,  have you experimented with this?
Pascuser
All these elements made me thinking about Hutchison's mineral cells.
He designed batteries working with some minerals (quartz and others) and charge it with DC High Voltage during a long time; and he gets a battery delivering some power.
This is the same that is done in the pyramid. Energy coming from the ground gives amperes (power) to the potential given by the quartz.
It is interesting to seek in comparison with Hutchison's work.
@Trawoeger: I agree completely that discussions will come AFTER successfull replication.
As I first built a 50cm pyramid because I thought you had a formula to compute reactor for all scales; I achieve my test with it, I won't just put it to garbage! When all will be over I will tell you here.
I sanded the reactor today (a small version of the reactor suited to the smaller pyramid) with my CiBi, 27MHz, but I have no amplifier yet. There is 3 watts output. I haven't the measurements you had with your multimeter, when you have hundreds volts AC around the antenna wire to detect the power emitted by the CiBi inside the reactor, I only have few volts. So 3 Watts is not enough.
You used a 27MHz CiBi or a VHF 140MHz or other?
I have ordered an amplifier to get more (35 Watts like yours) and will test it in two days.
k4zep
Quote from: duff on July 19, 2011, 04:04:00 PM
I also obtained my sand from pool supply.
Out of curiosity I dropped a neo magnet into the bag to check for iron content.
There were a few grains that stuck but I would not think magnet/non-magnetic grain ratio would greatly influence the reactor.
I'm thinking about removing all sand with iron content from the sand that will go into the reactor.
Hi Duff,
Don't know if it would make a difference but why not.  Keep the Quartz pure......
Respectfully
Ben K4ZEP
Pascuser
@Trawoeger
When I ask for measurement in your reactor, it is not to discuss and lossing time, it is in a way to design my reactor dimensions in order to follow the rule that with a scaling pyramid you have a resonant frequency scaled.
So I computed the dimensions to have all inductances of the coils half of yours and capacitor value half too.
But to have the good dimensions I must know some informations about your design.
I have to know the distance between your holes and some others (the lengeth of the adapter for weldind the tubes and of the part going in the tube). These informations are used to work really and not in a forum in discussions.
This is what I designed and why, with only assumptions of what is in your system. So I have to do it like a blind!
