Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
NickZ
    Hi Stefan and All:
   I was watching this video today of Kooler and his HV system, might work for something like is needed to charge the quartz sand in the reactor,  looks and is kind of dangerous though. Can't get too close to it.
    http://www.overunityresearch.com/index.php?topic=418.0
Trawoeger
@pascuser:
Congratulation and best wishes for your marriage:
You will get the complete Reactor at 20. August via UPS!
And it will be my personal marriage present for you :-)
Please send me your adress via mail.
ng, Tom
madsatbg
Hello Thomas,
Hartman found a network and an underground river, with the help of profesonal.
sifted quartz sand in small pieces
heated it to 100% dry
I loaded the "reactor" by Tesla transformer with 6000 volts
This picture shows what the voltage received from the reactor
Synchronize pyramid by cutting small pieces of "condenser"
I got about 250-260 mV AC
Multimeter is connected between the "plus" and ground piramide
the same  teminals a fan connected
after I turned it by hand
fan rotates one, two seconds
and stops
what happens, where I'm wrong?
Here is a video: http://www.youtube.com/madsatbg#p/a/u/0/r3I3s01A-zc
at best wishes
madsatbg
k4zep
Quote from: Pascuser on July 24, 2011, 01:32:16 PM
Thank you everybody for your comments. I will try the tests proposed.
@Trawoeger
Thank you very much for your proposal. Your experience to understand what's wrong is important.
Yes I am interested in a working reactor for the pyramid if you can design one and yes I will give a payback with all tests.
I everytime explain in detail what has been done and the resultats in my research forum, with pictures and videos to illustrate and that will not be different.
If you can design one working and are willing to send it to me then I will pay for material and shipping, that's normal and that's my proposal.
But I go on holidays tomorrow morning for three weeks (I get married in august) and will be back at home only for 20th august. I would have wanted to be there to be able to work on the pyramid doing all kind of tests, but I can't miss this appointment . As a teacher holidays are running until 1st september so I will have enough time to work on it when back; but not before 20th august.
Do you mind taking your time and waiting me until this date?
Whe can keep in touch (private message?) when you think you will have a working design (I will have access to internet during the whole period but can't bring my pyramid with me!)
Regards to all
Good morning Pascuser,
About 48 years ago I married.  It was the best thing that ever happened to me.  Enjoy life, enjoy wife and kids, someday grand kids.  In your spare time, enjoy the science of the Pyramid.  Good luck on all your endeavors.
Respectfully
Ben K4ZEP
conradelektro
Quote from: Pascuser on July 24, 2011, 06:13:07 AM
Did you get the same reading problems with your multimeter and the sand?
My video (in english with explanations inside):
http://www.youtube.com/watch?v=aWgscVRubFU
@Pascuser and all who do measurements:
Since some time I try to get electricity out of the electro smog surrounding us. While building different antennas and circuits I observed the following:
Whatever antenna I built, I always found 0.5 to 1.8 Volts when measuring with a good Multimeter in the AC setting, specially when I provide a good ground connection.
So, one has to be very careful when interpreting such results. Unless you live in a very remote area, you are surrounded by mobile phone towers, WLAN-transmitters, Radio and TV stations and power lines and you can see some Voltage whenever you have some sort of antenna on one Multimeter probe and a good earth connection on the other Multimeter probe in the AC setting. When you use a high frequency diode you can also see it in the DC setting.
It is easy to measure some Voltage, but it is very difficult to get some decent Amperage. So, the received "power" (Watts) is very little with a crude antenna.
A further interesting fact is that your body can either act as an antenna or as "ground". So, build whatever antenna you want (e.g. use a short wire), connect one probe of the Multimeter to this "antenna" and touch the other probe of the Multimeter (wetting your fingers will help) and you will see some Voltage in the AC-setting (0.5 to 1.8 Volt). The "better" your Multimeter is, the easier it will be to see a Voltage in the AC setting.
This post does not say anything about the Trawöger pyramid, it is just a reminder that electro smog is everywhere and influences measurements in the AC setting of a sensitive Multimeter. Trawöger claims up to 15 Watts from his pyramid, which can not come from electro smog according to my hobby research into electro smog. But the measurements I saw in the forums done by replicators with their "generators (copper tube coils)" look very much like electro smog to me.
Greetings, Conrad
