Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
Trawoeger
@madsatbg:
I am sitting here with wet Eyes, because you are maybe the first guy in OU.com with a proven first result, and you are willing to show this to the crowd. (we had some guys before, but the dissapeared in the moment of sucsess...)
Well, You are on the last step before sucsess.
First: keep all the mess away from the Pyramide. Every metal in a circle of 2 meters is poison for your Pyramide.
Second: keep the V12 directly to the floor and turn it between 2-3 degrees plus to north.
Third: use a smaller Fan
Fourth: Watch your Pyramide working the next month  :-*
You made my day good and now i will drink a beer :-)
If necessary, I can give you the final help even on Skype to get your wonderful Lady running.... I am so happy now.....
@conradelektro:
You can believe me, i am mad about pyramides since a very long time. Madsatbg shows us directly all the Facts you need to get a working V12.
I can check this, and i saw his Video on YT. There are some things you can´t fake .
So i can tell everybody. This guy have a working Reactor and this guy will be the first one with a turning fan....
(In this case, nobody is interested in any measurement BEFORE the fan is blowing... we enjoy it blowing)
madsatbg
Quote from: Trawoeger on July 25, 2011, 07:48:21 AM
thanks Thomas
I am so happy Ñ,оо,when you think that my pyramid
work and thank your I believe in free energy and people who openly share
;D
I join you and drink a beer for success and free energy
cheers  madsatbg
p.s.will follow your advice
neptune
@madsatbg . Here is something to try . If the fan will not keep running , do what Thomas did on his video ,disconnect and reconnect the fan a few times . If the fan shows a small movement as you reconnect , then I think you are very close .Once you get the fan to run continuously , do NOT disconnect it any more .Super congratulations on your progress so far . \remember TT says find a smaller fan .
One important question for you . On your pictures above  You show a copper object just to the right of your multimeter . It is sitting on top of what looks like a reel of solder . I assume this is a "reducer" or adapter to fit 30mm and 10mm pipe . Can you confirm that this is what you used to join the 30mm pipe and 10 mm pipe at the top AND bottom of your reactor . Does it fit over the OUTSIDE of the 30 mm pipe please . If I assume right , this is what I will use as it is available locally .
Edit . It looks like your inner pipe is 15 mm and not 10 mm?
Erdtaucher
To madsatbg:
Congratulation for this big step on the way to sucess !!!
You are the one with the golden fingers !!!
madsatbg
Hi Thomas,
I'm confused
I  oriented pyramid north-south, how to give another 1 -2 degrees north?
maybe I'm wrong totally
@neptune
Thanks for the congratulations, but still have time to travel
I used  the adapter 30 mm at 15 mm
wound 59 turns of the inner coil and the outer as the "reactor"
@Erdtaucher
thanks, steps to free energy I hope to do together
by sharing successful and unsuccessful attempts
mutual learning from their mistakes
