Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
Pascuser
Here in my destination for three weeks.
@Trawoeger
I will send you all that's necessary in an email. Thank you again.
@madsatbg
Great work!
I see that your compass indicates north besides your pyramid, but be very carefull that the north is not north besides your pyramid because the steel frame of the pyramid changes from many dozens of degrees the magnetic north on your compass.
So you must find the treu north with your pyramid very far away (and any steel or magnetic material far way), mark this north where you are over the node you want to use, and find 2 or 3 degrees more est and mark it too, then you put your pyramidover and if you put the compass besides, then you will see that the north of your compass is not the right one.
@DiegoPalm
On the way, I am very interested in what you do.
Here we have many workers that really do; I will follow all messages.
Trawoeger
@all_
I made a quick test with a fully copper Reactor ... same result as madsatbg...
(The fan turnes max a second,nothing else...)
So it´s important to get the brass distancer..make in on a lathe...
I wasn´t able to try a inner tube with 16mm because there is no piece in my shack.
Well, I get some great problems to follow all the threads, and give answers to allquestions,because the thread get to overloaded with necessary and unnecessary things.
In this stadium of  work, it would be good to give the áttention to the working guys.
So, please everybody without a V12 Construction in the garden, please let the constructors speak.
I will answer allquestions if possible...
@DiegoPalma:Congrats to your fine construction:
I hope, your Distancer in the reactor is still a brass-piece.
I will make a special calculation for your Reactor, because in your Country, the pyramides will work a little bit different then elsewhere. (But don´t worry, your V12 will produce something still with your Setup for the Start)
Maybe you can tell me more about your "Informing-process". I hope to find anything there,because for my distance-look, everything looks quit well with your V12.
The south-american Pyramides had some major differences to all the other pyramides worldwide. Maybe they had the best ones in anchient times... Soyour results are more than important for me...
Happy Pyramiding
Thomas
madsatbg
Quote from: Trawoeger on July 26, 2011, 02:12:55 PM
@all_
Thanks Thomas,
I will do a lathe brass bushings.
gegyx
Hello
Precisely, to build a pyramid structure identical to the original,
for avoidance of doubt, Thomas, I ask you to please, just tell us, the dimensions.
By giving us the right equality:
* For the side: ?
1 meter = c
or
1 meter = c + d
*For the base: ?
1 meter = b
or
1 meter = a + b + a
I've posted on
http://www.overunity.com/index.php?topic=11142.msg296069#msg296069
but I'm afraid you did not see it.
Thank you  :-*
DiegoPalma
Hi @ all,
I have the copper reductions instead of brass.
I talked to Thomas and he point it is important to use the brass reductions instead.
I will make the brass reductions on my next trip to town this week, but for the moment I tried the copper ones...
I have a 220v (input) and 20,000v output DC transformer. I am not sure of the output since I can't use my multimeter to test it, and I don't trust the seller too much.
In any case, I connected the positive to the cable and the EARTH to the outer tube. I test the high voltage in the inner coil and there was no shorts in the cable. This is my second attempt. In my first one there was a lightning (short) in the entrance of the upper 5mm hole and the cable. Now I rewinded again and it is good. Thank @ Neptune for the security advise.
I filled in the quartz sand (very dried) and checked the voltage with the multimeter negative in the reactor IN (bottom) and the positive some centimeters away around the reactor and now it is giving me some very low fluctuating voltage (like 0.120 to 0.450 volts) in AC and DC measures. In my first attempt it was 0.001 volts (no reaction).
Also is good to say that I lived in an area with few and week TV or radio signals.
I tried my best to find a water node with a couple of L wires in my garden. Strange sensation for a non believer when the sticks crossed completely in same point in different tries. But finally I found a place that seems to be the correct one.
I mount the pyramid with all components in correct place and connection, alignment to North-South (the front open face triangle to South).
I connected the 12v cooler fan to try stimulate the system.
Nothing happened when trying to move the ventilator. The multimeter reads 0 volts.
Maybe it is the copper reductions...
I will try again with the brass ones when I have them.
Any suggestion?...
