Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
zhak
Lucky quartz sand will give me a bag (free).
It deteriorated in stock at the store, became wet
k4zep
Hi All,
Working on my light weight Pyramid.  Behind is the base, front is the LH side, 1/4" Gypsum with edges done in steel/paper tape for
the electrostatic shield.  Takes time to get it right, but it will be done in a few more days.  I'm just quiet as I'm plodding along.  Working in the hallway of our Condo., very patient wife!!!!!  Worlds smallest lab and all that stuff!
Respectfully
Ben K4ZEP
neptune
@K4ZEP . Looks like fine work , and I like the way you work around problems . I was looking at brass fittings in a plummers merchants today , trying to find an off the shelf component that would serve as an end cap / reducer . I looked at a thing called a 28 mm end cap [compression . Although a bit bulky , this could be easily modified to do the job . It fits over the outside of the large tube . There is a gland nut or threaded ring that crushes an olive on the outside of the pipe to hold things together , but we could dispense with the nut and the olive , and just tape it in position . It is different to TT`s set up in that it fits over the outside of the pipe as opposed to plugging inside the end . One would of course have to drill the 10mm hole for the inner pipe . Based on your own theory as to why the brass is necessary , do you think this part would work ?
k4zep
