Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
zhak
Hello
Need Help!
When appropriate stage of the reactor filled with sand it must be connected to the radio station ?
What radio station can be replaced?
croco31
Thank you A.KIng21 for your info,
you are right, the best way for us is to replicate EXACTLY what TT has done, then after variations and experiments could be done.
OK, I keep my first version apart for future experiments (my upper cap is not very good anyway) : my 1m tubes ( 3x33cm) allows me to build two other versions.
Two things i noticed in the TT design:
- on the bottom side of reactor the brass (=copper+zinc) cap is soldered ( =copper+tin solder  + lead if not RoHs compliant or some silver if RoHs ) on the inner copper tube: this is a good electrical contact
- on the top the brass cap is just inserted to contain the sand (without compression not to change its structure) and fixed with adhesive tape only: not a very good contact if we take into account copper or brass oxidation.
It would be nice to avoid any soldering (to build easily the inner coil and trim the coil center).
I wonder if using a brass screw (soldered  on the outside of the brass cap)   and bicone on  to mechanically maintain the inner tube is adequate ?
In practice bicone will make a good electrical contact with copper: it is ok for the bottom edge (replaces the soldering the inner tube) if electrical contact is the key of success (not the presence of the others metals: tin+lead or silver).
madsatbg
Quote from: NickZ on August 08, 2011, 09:33:15 PM
  Madsatbg:
   The voltage of just the reactor is 2.7 volts. Can you tell us what is the mA?
The voltage is radiant, orgone or as he called the zero point energy.
This can not directly illuminate even LED, need to be transformed into
usually / "hot" / electricity.
For this purpose it is necessary a "reactor", which for now "refuse" to convert.So I imagine his work.
Quote from: Erdtaucher on August 08, 2011, 10:28:18 PM
Hy madsatbg,
I hope the sand I´ve sent you is working well in your reactor...
Hello Erdtaucher,
I did several loads of reactor.
But with a little deviation of the received voltage.
So now I can not say definitely of quartz sand that has improved or not
maybe when work as a whole pyramid... ;D
regards  madsatbg
croco31
Hi Matsatbg,
your multimeter show 2.479V AC.
For conventional physics it is very strange and unbelievable:
- where is connected  the ground of the multimeter ?
- what is the shape and frequency of the signal?
We must be very carefull with such high impedance measurement tool (>10Meghoms): it can collect anything from parasitic line grid effects.
Have you done the same measurement in different inner reactor conditions and same external conditions:
- reactor empty: no sand
- reactor filled with same sand but not activated
- reactor filled with same activated sand ?
Regards.
oscar
Quote from: zhak on August 09, 2011, 03:07:15 AM
....What radio station can be replaced?....
Hi zhak,
if you don't have the ham-radio equipment to energize the reactor you can use a special transformer that makes high voltage.
The first image in this posting shows such a transformer:
http://www.overunity.de/index.php?topic=1191.msg23628#msg23628
Also see Thomas' video
http://www.youtube.com/watch?v=jeHLYJLE60c
where he shows such a transformer.
In the country where i live this type of transformer is used to ignite central-heating systems that run on oil/diesel. This type of transformer typically has an output of several kV (kiloVolt) and run from the normal mains electricity system. So input is 220V @ 50/60Hz and output ca. 5 kV @ 50/60Hz.
If you find such a transformer you must only connect ONE wire from the transformer to the inner coil of the reactor. The other wire of the transfomer's secondary must remain non-connected.
The transmission was a '53 (Johnny Cash)
