Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
zhak
What can I activate the sand at home?
This must be done or not?
And please excuse my bad english. I work as a translator
madsatbg
Quote from: croco31 on August 09, 2011, 03:53:47 AM
Hi Matsatbg,
your multimeter show 2.479V AC.
For conventional physics it is very strange and unbelievable:
- where is connected  the ground of the multimeter ?
- reactor empty: no sand
- reactor filled with same sand but not activated
- reactor filled with same activated sand ?
Regards.
Hi croco31,
yes, very strange.Magic  ;D , so we can not repeat many attempts. :'(
This is not conventional physics. ???
Yes, I did it different measurements.
Please look here:
http://www.overunity.com/index.php?topic=11068.195
@zhak
I used neon transformer 3000 v 32 kHz.
But when using 6000 volts, here's what happened: :'(
regards  madsatbg ;)
neptune
@madsatbg . When using high AC voltage to activate the sand ,follow the advice of Ben K4ZEP . Only use one output wire from the transformer , connected to the coil . Do NOT connect the other wire to the copper parts .
neptune
@Zhak . You MUST activate the sand . You can use High voltage AC . Working with high voltage is very dangerous . If you do not know how to do it , get help from an electrician . You could use the transformer from a microwave oven . This gives 2000 to 2300 volts . Connect only one wire from transformer to reactor .If you get it wrong it will kill you .
