Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
fritz
Quote from: NerzhDishual on June 30, 2011, 09:09:41 PM
Any-way I will not try to reproduce this device because:
1) I have no 20 watts CB amplifier. It is slang called a "slipper" and is forbidden in France.
Is it forbidden to use them on an antenna or is it even forbidden to own them  ;-)))
An idling car running on  3cyl with one ignition wire "used" for proper formation should work either.
rgds.
neptune
I watched all the videos last night .Regarding quarts sand , many kinds of sand , and other substances are used for sand blasting .We need a better source , and this area needs more research . What is meant by underground water lines ?Are we talking "Leylines" here ?
  IMO dowsing is rubbish , or someone would have used it to win the James Randi $1,000,000 .That is my opinion , others may not share it .
     IMO the use of a CB amplifier is doubtful . 50 watt models are scarce and expensive , and you would not be wise to run them into a mismatched load , even for 2 minutes . The car ignition idea might be better , but could be very dangerous .Problem is , after all that trouble there is no way to be certain that the sand has been successfully treated . Couple that with the task of finding a successful dowser[ deviner] and suddenly the Lotto seems easy . Why not save yourself some pain . Just use your dowser to "devine" next weeks lottery numbers .
fritz
Quote from: neptune on July 01, 2011, 06:13:08 AM
I remember that he adviced to use high quality filter sand used for pool circulation pumps.
Leylines is more commonly used for the grid of force lines.
In this case I think its more about underground waterflow
From a physicians point of view, the rubishness of "leylines" and dowsing is on the same level as most of the overunity stuff (even if you dont want to hear that) - so I would give it a chance - even if the tradition of these rubbish trades back to ancient times and is even mentioned in the bible.
IMO the use of a CB amplifier is doubtful . 50 watt models are scarce and expensive , and you would not be wise to run them into a mismatched load , even for 2 minutes.
The amp used is somewhat "25Watt" model - consisting of one rf transistor stage.
I would doubt that it is capable of delivering more than 20 Watts
You can run them that way for 2 minutes - but maybe 8minutes will be too long.
If the case will reach 60 deg C it would be time to stop;-==))
This type is not scarce nor expensive - thats the base entry crap amp + crap swr meter;-)
The car ignition idea might be better , but could be very dangerous .Problem is , after all that trouble there is no way to be certain that the sand has been successfully treated.
I think there is a procedure mentioned in the video
So the remaining miracle is which type of wave or radiation is focused by the leylines - and can be reflected by gypsum in an attached pyramide. If the leylines  are just "work" to focus that radiation - the root-source would be somehow coupled to the magnetic field of the earth.
2 years ago, thinking about this pyramid thing - I already thought about some high bandwidth micro-"gravitational" effect. (not real gravitation).
On some not too serious dowser pages - they claim its kind of neutron radiation... but I don´t think so.
If this device is just tapping that energy - there should be a force interaction between the sand and the  tapped field  - if you load it - and its not OU
We´ll see it (or not).
rgds.
fritz
maybe its even possible to construct artificial "leylines" on large scale once you understood the background.
I remember that there was some mysterious chamber found in the foundation of the Gizeh paramid @ apex position. Control rod(!???) who cares ;.-))
WilbyInebriated
tb pawlicki's book talks about something similar to that fritz... interesting theory on the pyramids being used as global power/communications. pretty sure you can find the first chapters about the saucer online if i recall. not sure i ever found the later chapters about the pyramids online or not.
http://www.amazon.com/How-Build-Flying-Saucer-Engineerings/dp/0134024613
edit: the site that used to have the saucer part isn't online anymore (geocities) but the quick search (i'm leaving for the lake soon otherwise i would have done better) i did turned up the table of contents.
    1. MEGALITHIC ENGINEERING: How to Build Stonehenge and the Pyramids with Bronze Age Technology
    2. THIS CRYSTAL PLANET: How to Create a Worldwide Communications Network â€" Still Using Bronze Age Technology
    3. BEYOND VELIKOVSKY: Einstein’s Relativity Demostrated, Mining Pure Energy from Empty Space, and the Green Hills of Mars
    4. HOW TO BUILD A FLYING SAUCER: After So Many Amateurs Have Failed
    5. THE PHILOSOPHERS’ STONE: How to Transmute the Elements by Engineering the Geometry of Standing Waves
    6. TIME TRAVEL: How to Navigate the Streams of Time Through Hyperspace
this crystal planet was the chapter i was talking about. it's been twenty years since i've read it, but it was about how with a certain alignment of the earth's axis the schumann layer could be used to transmit radio signals. i was researching tesla back at the time and a friend gave me a copy to read because he was mentioned in the book. first time i ever heard bearden's name if i recall.
second edit: i found an online copy of that chapter.
http://newilluminati.blog-city.com/this_crystal_planet.htm
enjoy.
