Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
zhak
Here are found, can someone want to microwave a trance and his connection mark
GPS25
Quote from: Trawoeger on July 26, 2011, 02:12:55 PM
@all_
I made a quick test with a fully copper Reactor ... same result as madsatbg...
(The fan turnes max a second,nothing else...)
So it´s important to get the brass distancer..make in on a lathe...
I wasn´t able to try a inner tube with 16mm because there is no piece in my shack.
Well, I get some great problems to follow all the threads, and give answers to allquestions,because the thread get to overloaded with necessary and unnecessary things.
In this stadium of  work, it would be good to give the áttention to the working guys.
So, please everybody without a V12 Construction in the garden, please let the constructors speak.
I will answer allquestions if possible...
@DiegoPalma:Congrats to your fine construction:
I hope, your Distancer in the reactor is still a brass-piece.
I will make a special calculation for your Reactor, because in your Country, the pyramides will work a little bit different then elsewhere. (But don´t worry, your V12 will produce something still with your Setup for the Start)
Maybe you can tell me more about your "Informing-process". I hope to find anything there,because for my distance-look, everything looks quit well with your V12.
The south-american Pyramides had some major differences to all the other pyramides worldwide. Maybe they had the best ones in anchient times... Soyour results are more than important for me...
Happy Pyramiding
Thomas
thomas you said in your video you got a variety of sizes adapted already,would you like to post them please.Great work.Regards George
GPS25
Quote from: Trawoeger on July 27, 2011, 01:32:16 PM
Sorry formydelayin answering...I amalittle bitbusy now  ;D
what is that copper handle for thomas??can it be possibile to have those sizes please?Regards George
croco31
Hi all,
i have built my pyramid see attenhed pdf). :D
Now i work on a mean to activate the sand:
as i fear using high power 2KV line transformer (it can kill me). i intend to build some 1 or 2KV AC generator (high voltage but limited current) , using a ferrite transformer salvaged from an old 220V/+5V switching supply.
To do that, we need just an oscillator from +12V supply (accu for safety), inverting the transfo work. By supplying it  with 12V switched on the 5V side, we will obtain 1KV on the original 220V primary side.
If we use the transformer resonance, we shoud obtain 1KV sinusoidal AC voltage at around 400KHz (not so dangerous as 50Hz).
Is it enough to activate the sand ??
Regards.
FreeEnergyInfo
