Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
k4zep
Quote from: ainachara on August 25, 2011, 01:06:48 AM
Hello,
here you can see a beautiful replica of the pyramid body in late 2007, early 2008:
http://www.overunity.org.uk/cmps_index.php?pageid=TPP
ainachara
Clanz.... is a good builder, wonder what his results were at that time.  Have not received parts from TT yet.  Waiting for them but will test
my reactor/pyramid in the next few days, everything is finished, just hot here and busy with Main Shower remodel in the Condo.......HONEYDOOOOOOOs..........
Respectfully
Ben K4ZEP
k4zep
Quote from: ainachara on August 25, 2011, 05:55:41 PM
much to read, maybe this helps:
http://www.overunity.com/index.php?action=profile;u=9351;area=showposts;start=0
http://www.overunity.com/index.php?topic=695.0
ainachara
Hi Ainachara,
Reading back in 2007, it appears that TT says that a copper tube pyramid and a wood parymid won't work.  So I don't know if my
hybrid easy  to disassemble for transport unit will work or not........I'm bummed!  I'll follow through but now, who knows.  I wondered why he always grounded it to get it going, then un-grounded it afterwords.  Reason given was the HV charge that built up....now not sure............Just make that motor run, that's all I ask.
We continue,
Respectfully
Ben K4ZEP
neptune
Hi Ben .Do not loose faith in your pyramid yet . I think that it may be important for the plasterboard to be mounted on a steel frame . But not for structural reasons . Its function is to conduct current , and possibly react to magnetism . I seem to remember that you mentioned steel tape . So if you have steel tape running up the corners and around the base , all should be well . If you do not , it can still be added . There are many things you can use .If not steel tape , you could use the lightweight "angle iron " used to form corners on plaster walls . It is light and you can easily cut it with tinsnips , and bend it with your fingers .More hassle but not an unsolvable problem . Fix it with glue or even duct tape .
       It would seem TT is on holiday in Egypt .No doubt when he planned this , he expected replication by now . Lets hope he comes back and helps those who have built pyramids without getting results yet .Erdtaucher in Germany is doing some good work on reactors , and may have discovered an alternative way to activate the sand . I asked him to publish this but he wants to be sure first . We are so near to breakthrough , and yet so far . It is all , ultimately, in the hands of Thomas .
k4zep
Quote from: neptune on August 26, 2011, 07:35:47 AM
Good morning Neptune,
Taking a break for breakfast and sitting here at computer.  Actually, I'm going to try mine today INSIDE.  The quartz sand is in the oven getting baked dry, have added all the connectors to the fan/reactor, etc.  Have a suspension system that is good enough for first trials.
I'm still puzzled in that Thomas tells everyone to keep things clear of the pyramid but then shows his working inside his garage.  I KNOW there is no external earth powered electrostatic field inside as have done extensive work with electrostatic autopilots.  So his works inside with just the earths magnetic field and energy from a water flow but he has indicated that the outside ES field is connected with the pyramid or enhances its operation.  Second, he says voltage is not important, only amps.  Then shows the unit in one of the videos with a current/watts analyzer that shows voltage and current and uses that reading to show how much energy (watts) is being produced.  I happen to have a very similar one that I might hook up if/when I get mine working.   Unless the energy from this device is totally different and only current ? is used, then everything I know about power is nul and void! When you get down to the technical aspects of this, the nitty gritty, there is a lot of vague areas in the videos that you have to bypass and just keep going.  When he shows a lamp being powered with the pyramid, he does not show the amps and current in that loop or the voltage across the fan motor which is in parallel with the lamp.  But he does say it slows down a bit which is understandable. I'm still not clear as to what the actual output of the device is.  Is it pure DC or is it pulsed non symmetrical AC that averages out to DC with a capacitive loaded output or just pulsed AC when into an resistive  or lamp load.  I have watched the later parts of his series plus the troubleshooting video till I'm blue in the face and as a nitty gritty retired Technician, I realize it is not what he says but what he doesn't say.  Again, trying my best to keep it positive and just keep forging ahead on basic "faith".....Will have my first trial results by tonight I think. All I want is for that darn fan motor start and keep running!
Now about Erdtaucher, does he or doesn't he have a working unit.  IF he does, it should be all over the lists, if not, how can he be  finding
new ways to activate/polarize/poll the sand when he has no proof that it is working............I apologize in asking in absolute terms but again, basic facts is if its working, he has a good idea, if not working, he has a theory.........Right now, we are in a absolute phase.  IT works or it doesn't work.  Sort of like being pregnant, there is no in between.......After my first test the answer will be it works or it does not work, there is really no in between. IF it works will throw a video up on YouTube.   IF it does not work inside, I will then take it outside.  Problem with that, in the morning here it is cool but everything is wet with dew if I sit it on the ground.  In the afternoon, it is 92-94F outside.  But will try to find a parking lot with pavement that is dry and there is a water flow.  Ahhhh what we do for science.
Still haven't received the parts kit from TT.  That boat is slow as heck!
Thinking, I remain,
Respectfully
Ben K4ZEP
