Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
zhak
hi all
Ben K4ZEP
Read the copy of the letter you published.
1.Avtor letter describes a pyramid as a kind of a galvanic cell fueled by moisture passing rivers under the ground?
2.Eli still be able to someone to run the fan as he can to work as a member?
3.Togda pyramid does not fit the status of free energy?
4.What do other inventors?
k4zep
HI all,
Just messing around here.  A FLUKE 77 IV, on DC mV range setting, hi and low (Peak settings) enabled,  with the negative of the meter connected to the bottom inner coil of the reactor and the positive connected to the upper copper inner tube, I find that with mild vibration on the outer coil, I get as much as 150mv peak DC out in this configuration.  Next want to see if there is a differential voltage between the inner and outer tube with the brass between.
Respectfully
Ben K4ZEP
neptune
The last news we had was that Thomas was on holiday in Egypt . I do not know when he is due to return .
Pascuser
I saw that there are many problems with reactors. I would want to make the notice that everybody used high voltage to charge the sand in the reactor; but Thomas used 27MHz low voltage high frequency to do it.
Yes, he said that we could use too high voltage; but maybe what he thought is not totally right. He thought he had a way to calculate the scaling of the reactor for the pyramid and it wasn't. Once again I don't say this to be negative at all or criticizing; we all experiment and he succeded in something wonderfull and shares it with patience and sometimes things aren't what we thought it would be, that's normal.
What I want to underline is that what Thomas really did in the video that we try to replicate is 27MHz transceiver as a sand charging power circuit and that worked to have a working pyramid and everybody tries something else and nothing works... maybe there is a relationship? I don't say it is the case, only I ask the question because it has a meaning.
I continue to set up my system to load my sand with CB output. I worked on it this afternoon and after long hours of work I could have a set up that would not destroy the devices to allow a work.
Here is a video of what I did; sorry again for my bad English:
http://www.youtube.com/watch?v=lweVCNSAMrE
I don't have more time to try it today, so I will do it tomorrow evening or this weekend. As I have a new pyramid 1 meter scale finished, I will be able to try all the system within the end of the weekend I think (if weather is good).
I have some problem with the wire lengths of Thomas for his capacitor: I watched the video many times and counted the number of turns of wire for inner coil and outer coil to have a consistency with the length of wire. I computed, using the wire outer diameter (standard for 1.5mm² wire in Europe) and I did the work with a plastic rod for true: my calculations gave the same I had with my real work and this is different from what we see in Thomas windings... and there is a problem of coherence.
See my paper here:
http://img4.hostingpics.net/pics/531412pyra42.jpg
Maybe I mistaked in counting but I counted the number of his previous capacitor, and I could count the number of turn of the outside coil for its last capacitor (remember...he changed because of an error in the cutting angle) and the number of turn between the end of the outer coil and the end of the plastic rod; so I could calculate the number of turn of the inner coil and this time too it was the same number than for the first capacitor.
If his wire is not the same diameter of mine (that shouldn't, but let's say it) then I understand that we don't have the same number of turn, but I don't understand why the inner coil has less number of turns for him than mine and outer coil has more number of turns for him than mine. That could not happen, unless there is a difference of many decades of centimeters between each wire (I have less than 2 mm of difference between my wires because I first did a special work to assure that).
PS: I could buy a plastic rod 20mm in diameter made of PVC (you can't find this in a DIY store in France) in a company specialized in plastic boiling:
http://img4.hostingpics.net/pics/768716pyra27.jpg
Interesting.... 11 meters (the length TT gave for the capacitor's wires) is approximately the wavelength of a 27MHz wave... maybe this length of capacitor work because the sand has been loaded with 27MHz signal and this resonant frequency is still present in the sand at a quantum level and can amplify itself in standing waves in the capacitor when excited.
It is another important reason to load the sand with the CB and not with high voltage according to me...
