Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
AbbaRue
The device will cost less then $100 to build and about one Saturday of work.
One of the cheapest and easiest projects we have encountered.
10mm pipe would be about 3/8 inch here.  I am having trouble finding 3/8 pipe that's straight.
Everywhere I go only sells it in coils, so it has to be straightened.
1.5mm wire would be 15 AWG, but 16 or 14 AWG should be close enough.
For  the sand I will have to try the swimming pool places, or find quatz sand blasting sand.
For the high voltage a fly-back transformer driven by a 555 timer or transistor osc. should work fine.
If you keep the freq. high you won't experience much of a shock if you touch it.
Just use a plastic spoon to fill the tube and you won't need to get near it.
My biggest challenge is finding the space to place a 1 M pyramid, and it needs to be a telluric grid crossing.
conradelektro
Concerning water lines and dowsing:
http://en.wikipedia.org/wiki/Dowsing
Dowsing is a type of divination employed in attempts to locate ground water, buried metals or ores, gemstones, oil, gravesites,[1] and many other objects and materials, as well as so-called currents of earth radiation (Ley lines), without the use of scientific apparatus. Dowsing is also known as divining (especially in reference to interpretation of results),[2] doodlebugging (in the US)[citation needed], or (when searching specifically for water) water finding, water witching or water dowsing.[3]
http://www.youtube.com/watch?v=KeRCcFB66fU (Using Dowsing Rods To Find A Water Line)
I do not know what a dowsing rod shows (I know what people claim it should show, but proof is difficult). In my house a dowsing rod moves in a strange way when I cross a certain spot. I prefer to use two L-shaped iron wires (which can turn each in a ball pen plastic tube held like in the video). Over the years I tested various dowsing rods in several places (indoors and outdoors). Sometimes I see a movement in the dowsing rod at a certain spot, sometimes not. When I do it, it is not always consistent.
I met people who were very good with it (as far as consistency is concerned). In rural areas I know of people who find good spots for digging a well and they charge a little money for it. I also met people who claim that they can find "dangerous" spots in your house and I know people who had their house "measured" for that (by someone who charge money for it, not much money).
Whatever, the "finding of a water line" and the "electrocution of the quartz sand" are the tricky parts of the "magic pyramid".
Greetings, Conrad
neptune
This an open forum . Everyone gets to express their opinion . If you really want to understand dowsing , look up "Ideo motor response" . Most people can get a response from a dowsing instrument , be it a forked stick , "L" rods , or a pendulum . Like wise , anyone can talk to the dead , but getting a meaningful response can be a bit more problematic .
The divining instrument is usually responding to the subconscious mind , but it is of course moved by the normal muscles of the body .Why should the subconscious mind know the location of a buried object ? Note that divining is not restricted to water . Diviners claim to be able to locate oil , gold , lost objects , corpses etc . Some claim they can do this over a map , and do not need to visit the location . If you do not believe me , test yourself .Lay out a grid on a lawn or field . Get someone to push some nails in to the ground , so they are not visible . How many can you find using your divining rods ? If you can find them all every time , I would like to hear from you , and so would James Randi . Face it , this is a throwback to the Middle Ages , along with religion , angels etc .
        OK here is the deal . If nobody can replicate this , does TT agree to be burned at the stake as a witch for casting a bad spell on our Hazel Twigs ? I thought not .
neptune
Note that TT claims that the input energy comes from the earth in an upward direction .He has been working on this for at least 5 years . If I was in that position , I would have tried a variety of materials to try to shield this energy from the pyramid , as this might give a clue to the type of energy we are dealing with . If he is right , then the actual pyramid is acting as a concentrating reflector . The pyramid may not be the best shape for this purpose . We do not use pyramids to receive satelite signals , we use a parabolic reflector . OK maybe it is not so easy to make a parabola from gypsum board . Even if divining is real , it is not a thing everyone can do . The logical thing to do would be to walk around with a small pyramid connected to a meter .As always there are more questions than answers .
nul-points
