Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
a.king21
I've built several circuits including one using 400 volt capacitors. I am in the process of replicating the Danish developer device. My point is that it needs improving to get it to TUNE in to higher frequencies. Tesla hinted at tuning in to the "wheelwork of nature".
The reason I replied to this thread is that a lot of replicators didn't get anything with the pyramid device.  Not even a milliamp. P Kelly covers a pyramid patent in his free pdf book. I'm sure there's something in pyramids as they work on razor blades etc. It's just not for me.
Incidentally, I was using the Danish developers plate device to pick up radiant energy from  a usb plasma ball device. My meters were reading hardly any micro amps so I just left it for a couple of hours. I then carelessly touched the output wires and received a burn. I then powered a 20 watt unmodified CFL for a full 4 seconds at full brightness!  It taught me not to trust my meters. The Danish developer circuit can stand a lot of variations. I built one circuit from two cfl light bulb components for instance. So the circuit is a very useful one indeed. If you leave it on it's own it will even self charge the capacitors. I'm sure it will charge a super cap over a week or so with just a short aerial. The circuit can scavenge energy from just about anything.  Even the static from the front of a tv tube. But it is free energy and is perfect for experimenting with the  extraction  of energy from the earth as well as the air. I even used it to extract back emf from a pulsed electric motor. Hope this helps. Cheers.
gauschor
Trawoeger has written in the german forum that a "water vein" is required for the pyramid to work (as a grounding). I hope he has told that in the videos... (I don't know for what purpose exactly).
andrea
Quote from: a.king21 on July 05, 2011, 05:33:21 AM
@a.king21, I've tried to reply the circuit of the Danish developer with the proper plate, aerial, etc... I'm sorry it doesn't work. Look at the picture. I hope that could be from errors in the realization, I'm not an electrician  ;D would be interesting if someone else replicate and test it too
k4zep
Hi All,
Well starting the process.  Ordered 3/4 plastic rod to wind the tuning coils on.  Going to hardware store then Pet (fish) store, looking at
quartz sand.  Tomorrow will check out plumbing supply for the 3/8 and 1 1/4 hard drawn copper pipe and two end adapters. Might use CU end caps and center drill them for the 3/8 tubing but trying to build it as shown.
I sure wish there were a way to ask the good German fellow a few questions to clear up some fine points in his videos.
Then going to watch the videos again tonight and see if I missed anything.  Tomorrow morning early, will go to a nice field near hear and "dowse" and see if any water hot spots here in FL.  I noted that he uses either RF or a HV transformer to "charge" the Copper/quartz cell.  From the video, in this demo, he uses 27mhz RF from amplified CB unit or said that a 10 to 15 KV AC from a furnace transformer could do the job also.  Does anyone know if DC high voltage can charge the cell?  I can use RF, HV AC or HV DC, all available to me.  Going to pick up a roll of #16 solid wire tonight.  Might be a problem with the insulation breakdown with it when subjecting to the high voltage during charging...will probably add a couple layers of heat shrink tubing where the wire enters the 5mm holes in the 3/8" center tubing.  Just thinking here.
Ben K4ZEP
tjlitke
Does anyone know of anyone who has duplicated Thomas's Pyramid results yet?
