Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
guruji
Quote from: a.king21 on July 05, 2011, 05:33:21 AM
I've built several circuits including one using 400 volt capacitors. I am in the process of replicating the Danish developer device. My point is that it needs improving to get it to TUNE in to higher frequencies. Tesla hinted at tuning in to the "wheelwork of nature".
The reason I replied to this thread is that a lot of replicators didn't get anything with the pyramid device.  Not even a milliamp. P Kelly covers a pyramid patent in his free pdf book. I'm sure there's something in pyramids as they work on razor blades etc. It's just not for me.
Incidentally, I was using the Danish developers plate device to pick up radiant energy from  a usb plasma ball device. My meters were reading hardly any micro amps so I just left it for a couple of hours. I then carelessly touched the output wires and received a burn. I then powered a 20 watt unmodified CFL for a full 4 seconds at full brightness!  It taught me not to trust my meters. The Danish developer circuit can stand a lot of variations. I built one circuit from two cfl light bulb components for instance. So the circuit is a very useful one indeed. If you leave it on it's own it will even self charge the capacitors. I'm sure it will charge a super cap over a week or so with just a short aerial. The circuit can scavenge energy from just about anything.  Even the static from the front of a tv tube. But it is free energy and is perfect for experimenting with the  extraction  of energy from the earth as well as the air. I even used it to extract back emf from a pulsed electric motor. Hope this helps. Cheers.
Hi King I'm working on this experiment too. I've copper wire rapped to a plastic sheet for plate. Today I was building the circuit although could not find same caps in my scrap parts. Ok but near 160v 0.26uf ac caps and 25 100v dc caps.
I will try this tomorrow if I have time. You mentioned tuning. How can this circuit be tuned?
Thanks
k4zep
Hi All,
Just to show that I am serious, received my copper today to make at least two "Reactors", 3 if I
get a bit more 3/8's pipe.
Will get started on them this afternoon.  Have the sand, two different types, have the wire,
all power supplies, etc.  First to drill the hole in the end caps for the 3/8 .035 half hard copper pipe.
Outside is 1 1/4" .035 half hard copper pipe.  That's all for now.  Pix below.
Respectfully
Ben K4ZEP
neptune
Hi Ben , just some thoughts.  If you get a reactor built , and the energising circuit set up , you can experiment to see how hard you need to hit the reactor to disturb the sand . This info will be useful later .While you are set up , you might want to try both types of sand .
k4zep
Quote from: neptune on July 09, 2011, 07:14:29 AM
Good Morning Neptune,
Should have the reactor built by the end of the day and then the "playing" as my wife calls it starts.  Your suggestion is excellent and will keep notes as I go along.  IF I find anything interesting, will put a video of it up on YouTube.
I don't have my long plastic rod yet to build the tuning coils but it is in the mail.  Obviously the motor pulses the "energized" or polarized sand and possibly the back EMF spike also energizes the sand to kick back and hence the output.  A Pot. in series with the motor or a pulse generator with variable output will be a useful tool here in the initial steps to get a handle as to how it responds/works to excitation.  As to how the "water" lines provide more power, I don't have a clue yet.  I also don't know if the 7.X hz frequency has anything to do with it.  So much to learn here!
Going to Home Depot in a little while to pick up misc. stuff.
Respectfully
Ben
duff
Hi Ben,
I'm going to build V.12 also - I built V.6 back in 2007 and it set in my garage up until about 3 months ago. Then I threw it away. Seems you never know what your going to need...
I'll be working on the pyramid mornings, when it's cooler in the garage,  and the maybe the reactor in the afternoon.  I'm not a fast builder - wanna make sure I get this right.
It will be interesting to see how you handle the pyramid construction in the condo...
