Thanks to ALL for your help!!
Bruce's Journey to Coral Castle
Started by Bruce_TPU, July 03, 2011, 12:55:15 AM
Bruce_TPU
Bruce_TPU
Shokac
Beautiful pictures Bruce!
Do you know perhaps if something is put in a bottle? (Water, oil ...)
Bruce_TPU
Quote from: Shokac on July 03, 2011, 03:46:53 AM
Hi Shokac,
Thank you!
As for the bottles, I honestly can't remember what specific things they said Ed kept in them.  Water and Oil would be a fair guess for some of them.  Ed was a "scrapper" and used many automotive parts of his day as salvage and turned them into useful items.
Cheers,
Bruce
Freezer
Great pictures.. I wonder if Ed's bed floated as well, looks very uncomfortable.  The metal spikes in the coral remind me of the Hutchison effect.
