Water and gravity: look at this video
Started by andrea, July 03, 2011, 06:11:22 PM
sm0ky2
The two hold a proportionality akin to voltage and current
The pressure state representing a static value
And the gravitational momentum representing a time derived motion.
An acceleration force, applied over a distance, of one fluid transitioning through another.
sm0ky2
In nature, we would view the pressure system as being the energy that causes a rainstorm
And the gravitational component being the combined momentum of every drop of rain when it hits the ground
As you can see these are two greatly different numbers.
sm0ky2
There is a 3rd component that that maintains the proportionality
The "resistance" component
This is the fluidic resistivity factor
At a given pressure, 2 fluids have a factor, similar to friction,
Wind resistance, etc.
Which controls the transition rate,
This is the "g" constant.
At standard pressure (atm), using air as the first fluid,
This is 9.8 m/s/s
sm0ky2
Much like electricity, fluids take the path of least resistance.
For this reason, the density of the lighter fluid affects the constant.
sm0ky2
In the absence of gravity:
The pressure system continues to operate exactly as prescribed.
All energies are still accounted for.
We simply no longer have the gravitational component.
The Cartesian Diver fails to dive, even though the air compresses.
This proves that gravity can be used as a power source.
