a strange finding
Started by Cairun, July 09, 2011, 11:54:16 AM
Cairun
Hi all,
I found something interesting lately, something that has intrigued me.
I had two rectangular magnets in repulsion; and I placed a bar of steel on top of the two magnets.
I found that the attraction between the bar and the magnets would be stronger when you forced the magnets together than when they are apart.  I do not understand what is happening there.  I would appreciate it if anyone can provide answers or opinions.
Thanks,
Alex
futuristic
If I have time I will model this in FEMM, but out of the head I would say that when magnets are close in repulsion the path of magnetic lines is shorter and the density of magnetic field on the opposite end is therefore greater.
futuristic
Here it is...
Huh the sim shows that force is greater when there is no magnet near in repulsion mode:
Only one magnet (iron block is the one on the right):
http://file.si/pfiles/183617/no-repulsion1.png
Two magnets in repulsion:
http://file.si/pfiles/183616/repulsion1.png
Perhaps I did not do the simulation correct? FEMM file is in the attachement (change the extension to .fem)...
MrMag
My guess is that since the magnets are opposing, the flux lines are fighting each other. When the bar of steel approached the magnets, the flux will tend to be attracted the bar instead of fighting the other magnet. I hope this makes sense.
Cairun
Quote from: futuristic on July 09, 2011, 01:32:25 PM
Here it is...
Thank you for answering my question.  However, the set up I had was different from yours.
I had the iron bar centered and on top of the two magnets.  Would you run the test again with this set up, please?
I downloaded the attached program, but I was not able to change the file extension to .FEM.  Do I need a special software to run this program?
Thanks,
Alex
