Background discussion of TT`s Pyramid
Started by neptune, July 16, 2011, 10:19:32 AM
tarcius
Quote from: neptune on July 30, 2012, 03:26:23 PM
I wasted much more money than I could afford on this project. It does not work. This guy is sick in the head. Instead, work on something that will give results. Try the Hydro Differential Pressure OU device. No witchcraft no flim flam, no magic water devining, just pure physics.
Yea that Hydro Differential Pressure project is very good i read alot about that. is there some kind smaller device and simplier design so it can be made just for profing.
hey i dont have any money barly paying my basic bills. But i have strong will and very optimistic mind and that helps much.
Have found some sponsors that are willing to risk their money on pyramid project and why not i get all the fun.
As i see this must work. its very similar to bendini system where u have pulses that activate magnetic field here you activate piezo effect in crystals that in return give back more.
Now i dont go into positioning of pyramid because i think thats hogwash. i think that this setup dont need to be in pyramid at all but who knows.
I made one pyramid out of drinking straws few weeks ago. Covered it with aluminium foil and get half volt out of nowhere.
i have video of that i will upload it later.
one terminal on alu foil and another terminal put at tip of finger and that tip of finger touch alu foil on another side and there is half volt 2 microA.
Tried mesuring on diferent locations but it stays constant. from 480 to 700 milivolts
Please try this experiment its very simple to make.
a.king21
Tarcius:
There's a type of con called an "investment scam"
This is where an individual makes an OU claim and starts to get  a following.
After this he approaches various venture capital companies who arrange funding.
This obviously involves a nice big salary and investment in equipment and expertise.
Trawoeger made various promises to replicators promising to send special materials.
Nothing happened. Then he started to cease contributing to the forum which he started.
Draw your own conclusions.
However if you have some good ideas then why not start your own thread.
If you have backers, then all the more reason. There is a lot of global interest in pyramid power.
I have got just as much power as you by simply placing two probes into the earth.
Nothing to do with pyramid power. Just an earth battery.
I also got the same power using a small aerial. Turned out to be mostly induction from the mains.
Anyway, good luck.
tarcius
Hey a.king21. Thanks on explanation it is troubling what you say. It's shame that this kind of people exist.
you are right i will make my experiments and if something shows up i will open new thread. Thanks on heads up
As promised here is video on i made few weeks ago.
Voltage is present all the time. tried it at home and at work result is the same. Also tried different voltmeter.
Strange thing about this is that you get same result whenever you put red electrode on body it only matters that you touch pyramid nothing else.
Current is about 2 microA but that varies.
http://www.youtube.com/watch?v=4TduiksJ0xo
neptune
As I said before, Trawoeger is guilty of wasting the time money and materials of researchers worldwide, for motives we can only guess at. Whilst I am interested in your experiments, I think what you have built is a crystal set. [The simplest form of radio receiver].What are you hoping to achieve? If it is freedom from the grid, build your own cheap solar.
      Pure research? look at the model on Hydro differential pressure OU system. Or look at the works of Jean L Naudin.
Void
Quote from: tarcius on August 01, 2012, 08:37:07 AM
Hi tarcius. There is lots of electromagnetic radiation all around us coming from the mains
lines as well as any electric or electronic equipment that may be plugged in, and all the
radio and TV broadcasts and cell phone communications etc. that goes on around us.
Because of this, it is not uncommon for a voltmeter to give voltage readings in the
millivolt range even when nothing is touching the probes. If you touch to your body or metal
objects it would not be surprising to get a reading in the 500 mV range.
To compare to your ~500 mV readings, I took a big sheet of aluminum foil and did some
voltage readings with the aluminum foil sheet placed on my desk close to my computer,
similar to how you did your voltage measurements in you video, and I was reading
around 480mV to 525 mV, but the voltage readings varied by a few hundred millivolts if
I moved the aluminum sheet around to other areas. This is most likely just due to the electromagnetic
field produced by the computer inducing a small voltage in your body and in the aluminum foil.
This sort of voltage that is induced by electromagnetic fields coming from the mains and electric
equipment etc. should not have any power associated with it (can only produce a very weak current
at best).
Now if you can produce a few hundred milliwatts or higher of useable output power
from such a voltage then that would be worth investigating further. I would first check
for a cell phone tower right near you, or a short or fault in electric equipment. :)
Typically voltage that is induced from surrounding EM fields will fall off towards 0V
as soon as you try to draw any current off it. When trying to make voltage measurements
in the millivolts range or lower on equipment, it is a good idea to make sure you are well
away from any computers or other electronic equipment, and for really small measurements it is
probably a good idea to have good EM shielding around the equipment being measured, if possible,
such as have the equipment mounted in a metal box or placed in a shielded container.
