Background discussion of TT`s Pyramid
Started by neptune, July 16, 2011, 10:19:32 AM
Trawoeger
@gegyx: Tous parlons anglais ici. C'est pourquoi, je peux aussi répondre les seulement anglais font une passe.
Je parle allemand, anglais, italien et français, mais ici nous devons parler anglais.
Questions en français s'il vous plaît à le mien mailadresse.
Sa Va, Thomas
madsatbg
Quote from: Trawoeger on August 14, 2011, 11:19:53 AM
@madsatbg: I made some test with most of my Sands. I can´t find any little piece of metal in all my sands!!!!
(tested with neodynum-magnet, stirring in my sands and visual check after stirring)
ng, Tom
Thanks Tomas.
Continue our search...
k4zep
Quote from: madsatbg on August 14, 2011, 11:29:53 AM
Thanks Tomas.
Hi Madsatbg,
Don't know if my quartz sand works or not yet but just checked it and there is no magnetic material in it.
Respectfully
Ben K4ZEP
neptune
The sand I collected from a local beach contains about 1 to 5% magnetic material . It is black in colour , and is weakly attracted to a ceramic magnet . I have an idea which I will test tomorrow . Thomas says that when filling the reactor with sands , The sand will "fly about" due to the high voltage or high frequency .My plan is to test if my sand reacts to high voltage static electricity . If you get a length of 40 mm plastic tube of the type used in the reactor , you can charge it to a high voltage by rubbing it hard with a cloth . You may need to try different types of cloth . You will know when it is working , because you can draw 2 cm sparks from the tube with your finger which you will see and hear . Charge the tube and apply it to some sand , and see if it attracts it . This may even be a way to separate the good sand from the bad . I do not know that sand which is attracted to the tube will be good for a reactor , but it is something to try .
neptune
To those of you who may still be a little worried about pyramid angles and dimensions .Go to Youtube . Enter the following in the search box . Pyramid Magnet-free energy-english subtitle . Irrespective of the user name , the guy in the video is unmistakeably Thomas . In this video , he talks about the early V6 version .The date of posting is jun 2009 . Ignore any reference to the magnet , which he has subsequently said was a " security device " which operated a reed switch inside the reactor . Early on in this video he says and I quote .YOU SEE A PYRAMID MANUFACTURED OF METAL . THE ANGLE AND DIMENSION OF THE PYRAMID SEEMS TO PLAY NO BIG ROLE . So things may not be quite as critical as we had supposed . Another strange thing . He stops the fan by removing the magnet [thus opening the switch] When he replaces the magnet , the fan restarts . We are warned not to disconnect the fan in the v12 version . However , the v5 reactor was very different , and used a different sand conditioning method .
