Aether and what it is.
Started by jbignes5, July 26, 2011, 03:13:51 PM
jbignes5
 I think I should have said "If we figure out that mechanic of the universe we can Generate (channel) the energy we need to survive as a race.
We are truly beings of energy in a matter casing. We consume free conductors for this to operate correctly and use that to conduct our energy needed in the process of growth and our movement of our casing(body). If you really understand the biological effect we are merely a capacitor for our energy and the reason we age is because we leak that energy. This means in the case of our energy or charges loose charge over the time we age. Our ability of our charge to hold our matter together becomes less as we age. But figure out how to add charge back to our capacitor and age reverses. We bind back together and our matter holds tight again.
The charge we hold is essentially our soul. It is The Aether held into specific patterns. Our cells are our programming over our life charge or soul. The Brain is the control interface between our Soul and mechanical body. We are merely what we have been building our whole technical life. Computer/Robot. What differentiates the two is that our charge can be programmed by modulating the string of Aether it is based on. Not so strange when you look at the brain. It looks like the same thing that our internal charge looks like. Remember the fractal nature of nature. How key aspects copy from scale or resolution set to scale or resolution set. This repeating of the basis of charge makes perfect sense. So when people say that, we are the Universes proof of existence because then it can experience itself, they are absolutely right.
jbignes5
 So I guess that knocked all responses? Hmmm...
What we have to understand about this method of potential only is that it has to be shielded by a static shield. This means just metal covering the outer portion so that it keeps charges inside via their own induction. This way the charges stay inside the system till you want them to interact with the environment and do work with the flow you make.
Tesla had the perfect idea. Why change the material of the conductor when you can change the way you provide the current. Or in this case Voltage with near zero current. All the current is transformed into this super high potential that does not interact the same way as a heavy current with resistances. In fact he devised that it would be near 100% transfer of energy to the intended target from the source. This improves the efficiency to only the device parameters. The conversion was used inside the device and drew in more along the way because high voltage attracts more energy to the system if you include an broadcast array as the collection area. This raises the potential if you understand the design of the charge pump action going on and coincidentally raises the conversion inside the device with the added charges from the environment. Plus there is the transformer action that a Generator/motor would provide as well. Kick start the process with a single battery like starting a car engine and brrroom of it runs.
Well the motor should work as described anyways. The added stuff like antenna array is icing on the cake.
This motor that he talks about actually works without using magnetics in the traditional sense. It works with the electric field. Which is an entirely different beast all together. The magnetic field is shorted into the iron core and only the electric field is used in the motor via induction and consequently lower voltage and higher current as the result of the design. See he figured why not use the magnetic field in a torrid. That way as it came up to power it would lobe out from the iron when the process hit a certain speed. This was a driving mechanism but the torrid allows one to just push the filed around. The would only let the electric field be the inductive field and if the rotor coils of the genny were much bigger in size it would lower the voltage and raise the current in the rotor field allowing to to lock onto the magnetic field spilling out of the torrid when it saturated. The thing is the motor ran backwards then... Instead of when you slow down the rotor it used more current if you slowed down his rotor it made more current because it would generate more current from cutting across the filed lines of the electric field the torrid was providing. He literally used the transformer action inside of his motor to convert the high voltage he provided to convert down to low voltage and high current Without much cost. Well it wasn't free but he could pull in more charge from the environment because the motor was designed to create a vacuum to work with.
jbignes5
 Speaking of static shields I think I may have unlocked the Gray Tube. The metal grating around the wire with high potential is supposed to be a static shield and not a conduction grid. It is to let charges in from the environment via the holes in the metal and trap charges via induction provided by the grid around the wire just before the spark gap so that it could be extracted through the gap when it fired.
They got it wrong because it was meant to deceive people who didn't know what Tesla knew ,who was a favorite subject of Gray. When you ground the shield the effect disappears. So anyone who has a model of the gray tube please disconnect the wire to the grid around the spark gap and see if it works as described. It had nothing to do with 3 way BS crap that others talk about. It is merely an inductive bottle with one way valves(grids) for free environmental charges to enter the system. You could say it was an inductive bottle that would compress extra charges onto the now conducting air in between the spark electrodes. Literally squeezing the charges into the wire before the gap.
When you look at it via static laws induction pulls charges around in metal. One side becomes depleted of charges and appears to be the opposite polarity of the attracting static voltage. A Pulse in this case is a static bubble within the network. When the static shielding receives the attraction from within itself it makes the external surfaces depleted of charges and it draws a strong attraction of the free charges in our air. These charges get partly pulled off of the Aethric conductors and shuffled into the induction bottle. This bottle is self adjusting. But materials have limits as to the base charge level they have fundamentally and that limits the ability to provide a perfect transfer. I am thinking Aluminum is such a near perfect transmitter for this process. It reacts differently when exposed to a normal magnetic field then say Iron. It doesn't hold or latch but it will effect the drop rate of the magnet when used on an aluminum plate. This means it is only reacting with a certain sub component of magnetism. This component seems to be eternal once formed as in the case of a magnet. This is because there are mini guns in the smaller scale area. We do see this effect by using a liquid magnetic material like Ferrous fluids. When subjected to strong magnetic fields this fluid grows very intricate patterns that in fact look like what it inside of the magnet. That form is what gets locked into the matter substructure and creates the flow that never ends. Well until the internal structure receives a shock or external charges(Heat) are applied. These internal structures are merely a flipping of the Aether charges trapped inside of the matter. As we all know or should know is: heat is pure charges applied to the environment. Weather that be the medium of space or any other medium wrapped in matter.
At some point in time we were cheated into being slaves for the ones in power. They give us little scraps of freedoms and that satiates us for some odd reason. We have been lied to and I think Maxwell was onto it all along. You know what happened to the other half of his equations. Poof... Right?
We have had little clues given to us by the smartest man on this planet. He was so smart that he buried the secret right in front of our noses so that we might eventually get tired of this bondage we seem to be in. The system we find ourselves in is not designed well to stand anything but greed and it will fall. We are seeing this now. The government has stopped listening to it's constituents any more. They do what they feel is right and not letting the people have a say in it.
So I guess it is break away time. We need to take back our land and start living right again. We destroy everything we touch now. We pollute our lives and never give it a second thought in general. Yeah there are some organizations that have helped clean up some but on the whole we just can't break free of the lies we are getting told. Then when they get caught in those lies from an outside source they say it is a matter of national security. Why is that?
Our illustrious president of the U.S.A asked for help from the people and asked for Ideas. When I sent a e-mail I got an answer that literally said that they appreciated my ideas but they had a course set already... What? Why bother asking for Ideas then? Politics is a sham in the United Un-United States. We can't even agree on anything anymore. The congress is useless. All they do is bicker and let others bicker in their place. They are nothing but inramps to money for their state. "EVERY" bill has attachments galore. A cut to Idaho for letting it pass. Wait NY wants it's cut too... I mean they don't even care about the bill's contents anymore. Now they come to the table with a laundry list of attachments they are seeking. They stonewall the bill till the attachments are bonded then pass it to collect their dues. We are literally sucking our own government dry. We lie cheat and steal to avoid proper taxation of the super rich because they don't want to help out. This coming from the same people who made that fortune right here.
We need a change. We need confidence in our government again to both accept that they have done us wrong and to fix the deception. Restore our rights given to us by the original peoples of the United States. Those rights should have never been limited in the least bit. If an amendment gives additional right or clarifications then they stay but limiting amendments are to be removed. We need common laws back and not corporate maritime laws like it is now. Prohibitive law is only for maritime situations. You might think that the united states is small but it really isn't and corporate maritime laws do little to help. We need to get back to education of even our adults. We Need to increase our understanding of this place we live and start to actually work on relations with one another. We are seriously lacking in our ability of tolerance and are quick to pull the trigger to get revenge for the ills that affect us. Instead of bringing us together and becoming stronger we separate and divide our selves becoming truly un-unified and weak to deception.
Hmmm...
jbignes5
 I have had the chance to think about what magnetic fields are in my theory. If we understand the fluid laws governing this Aether you will start to see how the magnetic field works. If we channel the Aether through matter by aligning the Aether inside then we create more potential inside that matter. This has a fluidic response like and island in a stream. The Aether flows around the potential (electric Field) and bunches together forming lines in the Aetheric grid or network. This is merely a magnetic bubble that form around this higher potential in the matter. So the magnetic field is only a response of the Aether to flow around the object. A magnet therefore is a ligning up of the Aether inside of the matter and creates a channel and order of that channel as it flows through it. This is where the power is coming from in a magnet. Once aligned it does nothing but channel The Aether it's entire life for free. We are taking advantage of the flow of Aether trough our space and matter has way more density then outer space of this Aether. We have ever lasting energy because of this flow of Aether and how we roll in it as it moves by us. Time is there but it is only there because matter exists. Where matter doesn't exist in huge quantities, like in space, the Aether is less dense and has less effect on our matter. This is why our clocks don't match satellites in space. Time is relative to matter and masses of matter. The further from masses of matter the less the Aether ages you or spins your atoms.
With this new revelation Black Holes start to make sense. The crystal is actually trapped there in the hole or tear in the Aether. The Aether being the boundary of this energy mass of (+). The hole is actually being wedged open by this crystal (which is just super compressed matter). The emission we see are the leftovers of the conductors being sucking into the Black Hole. On the scale of Black holes this kinda makes sense. I think this might result from the conductors reforming huge masses from the compression of matter to it's ultimate density. This might make matter flakes appear to have no signature at all electrically and flow through the grinder of the Black Hole. Dark matter suddenly makes sense. The matter isn't detected at all because it has no signature to speak of. Then matter reformation occurs and the flakes bind to the free charges that were also flowing around the apex of the Black Hole. The matter jets spewed into the conductor saturated space and flow back towards the mass of positive charges of The Aether disk this allows them to reassemble back into matter and now we have space dust among the many many different sized charges that form into the based components for matter. Gasses and everything that matter has organized into.
I also believe that the Aether has a memory. Meaning that it is much like a record player. As it spins around again A faint organized pattern would have a great effect on the matter formation at that specific space and how it reforms. You could say History repeats till it gets it right. Slowly modifying itself the more it passes the same point,if it passes that same point. So you could say evolution is very true. All things evolve because they never traverse the same spot in the Aether the same time twice on average.
I am starting to think the 26k year cycle of our rogue planet is because somehow it became anchored to the Aetheric Disk and it takes 26k years to complete one revolution of the Aetheric disk. Being the Galactic year so to speak when talking about a cycle of this Aetheric disk.
According to Sumerian Texts the Annunaki came from this rogue planet. If they are anchored to the Aetheric disk then they wouldn't age at all and time would mean very little to them. They would also be moving much faster through space when compared to our matter. If we understand they are not moving through the Aether like us. They are moving at the speed of the Aether or close to it meaning that the Aether wear it little bits over eons of time that we see. They might appear to be god like if they slowed down to our speed because they evolved little physically. They are the first race and only knew we were here because of the great event that we crossed the same Aether at the same time causing a collision. They were curious about the origin of this collision and discovered another race in that investigation. This is where the Sumerian texts pick up in our time. The Annunaki were very very technologically advanced and maybe that is what anchored them to the disk in the first place. It could very well be they are not anchored but figured out a way to channel the Aether around them and stopped moving all together in space. I'm wondering what would happen to an atmosphere if you pumped gold into the Ionosphere. Would it channel the Aether around it as well? And was this the reason for them to stay here and get us to mine it for them. We have always known that gold is precious maybe this is where we get this feeling.
This brings up the stories about Ormus. And what it really is. Maybe it is the distilled Aether conductors that they made from gold to make a shield around their planet and latch them to the Aether disk. Now don't get me wrong in this situation this would impart no inertia at all and would change very little because I would think they would slow down very slowly from the speed they were going but If done wrong like it was it created collisions with their moon with us. This could have been the beginning stories of the Sumerians as they used a planet as a vehicle. They could have ran out of Gold to power the shield and was forced back to growing old. But there was a group of animals on a planet that could be used as stock for workers to get that gold.
Offering were merely them collecting the resources they needed for survival and the escape to where they wanted to go back to. They fully intended to wipe us out but one had a close relationship with the Sumerians. The author of the genetic code we possess did not want his creation to end. He wanted for us to have life and he bucked the powers that be and gave us a way out. Unannounced to the powers that be we grew into this society and it could be that they now are not interested in us becoming extinct but curious about our progress. Of course we having an animal code tend to create dogmatic religions that are only out to control mass amounts of people and at the time this was for a good reason. We created religions to help us by the dark times that all of humanity are effected by. Now that we are becoming more connected it is time to shed the Dogma and find the truth that was left behind for us to find. This information is buried in all of the contexts of our religions and we need to separate the disinformation from the truth and get back our knowledge. It is there for us to find if we only look and read without interpreting the information with our limited understanding of where we are or even who we are.
If Christians believe the bible is the truth then they must believe the sources of that bible and the Sumerian texts speak of many of the bibles topics, almost in verbatim before the bible was written. Jesus knew the truth of the origins of man and that is why he held powers that mystify us. He must of had access to the truth and decided it was time to try and steer man in a good direction of love and peace. Maybe even prepare us for the truth eventually and instill a moral upstanding wisdom that might filter into our minds through powerful belief system that the old regime abused and manipulated. Jesus was a scholar before he was "Jesus" the son of god. His father held high position in the religious system and probably had access to the truth about man's origin. Jesus defiantly stood for a change of the old guard so to speak.
Dave45
Quote from: jbignes5 link=topic=11258.msg29
If you wanted to setup a deception and you lived all through time what would you do, you would leave clues that would verify your deception scattered out through the timeline, be careful study this, and listen to that small voice called your conscience.
I really liked your aether theory.
Dave
