Laset Fuelless Generator
Started by importfanatik, July 27, 2011, 01:19:35 AM
topothemtn
futuristic.
  With your design whats going to move the magnet??
  Topothemtn.
futuristic
Short pulse trough coil every few seconds to pull the magnet down then let it swing up and down on the spring.
Or even better constant pulses to pulse coil with resonance of the spring.
Like jumping on the bridge, you need to jump at the right time and whole bridge will start oscillating.
This way you would put minimal amount of energy in the coil to sustain constant movement of magnet on the spring.
topothemtn
Do you think you can use the same coil to move the magnet and to get power out of the same coil?
futuristic
Sure, must diy pulse motors works like that.
Low-Q
Quote from: futuristic on July 29, 2011, 02:52:41 AM
That pulse corresponds perfectly to what energy output you get from the coils after the pulse (+ loss). Loading the coils will break the magnets movement so more frequent pulses are needed to sustain the movement in the magnet = supply more energy as you take more energy.
Vidar
