Help with 3 Pole Bedini wiring
Started by zac123, August 02, 2011, 11:02:45 AM
zac123
Hi all,
i'm slowly making progress with my 3 pole bedini but i'm finding it difficult understanding the wiring schematic.
I'm just not understanding where all the different ends from the coils should go.
I'm currently drawing out on a bit of paper how i think everything should be connected then i'll upload that for people to see.
zac
tagor
Quote from: zac123 on August 02, 2011, 11:02:45 AM
Hi all,
zac
did you see this video ?
http://www.youtube.com/watch?v=1oHFvI9EsBg
zac123
Quote from: tagor on August 02, 2011, 11:59:25 AM
thanks. yes i've seen that. i also got the CD with my kit (but a longer version)
the problemis for me is that he never actually explains where to connect the different coil ends to and because i dont understand the schematic very well this is a problem for me.
tagor
Quote from: zac123 on August 02, 2011, 12:22:49 PM
it is more simple here :
http://www.eagle-research.com/consultation/BediniNotesGW.pdf
mscoffman
The schematic shown seems to be correct - but I agree it's
operating principle is hard to see immediately.
The diagram could be enhanced by showing the magnets embedded
in at 120 degrees from one another in the wheel.
The thing to understand is that the slave coils and the drive
coil are identical each driven by their own transistor amplifier.
But all the transistor bases are driven in parallel through base
resistors from pin 2 of the switch. So pin 2 of the switch is always
input signal. The switch reconfigures how this input signal is generated.
The signal coil is wound in on a common iron core with the drive coil
just like in a single coil Bedini, but because each slave coil also
has a magnet under it at the same distance so the signal coil
creates the drive simultaneously. The drive and signal coil
look like a transformer on the schematic but the wheel magnet
affects that.
The charge battery connection is the same logic as the standard Bedini.
:S:MarkSCoffman
