PLEASE READ THIS-MAJOR BREAK THRU FROM BILL MEHESS
Started by billmehess, August 12, 2011, 11:13:05 PM
billmehess
My prototype is completed. I am getting a steady 5.2 volts output. For the last week I have been getting some wide voltage outputs and spikes but I solved the problem and the output is steady.
I was able to use a Faraday cage at a local University and found that the output was not affected.
RF signals are not relevant.
I am going to start a 30 day test to check on voltage output and stability. Also at the end of the 30 days I will examine all the componets to check for any signs of desegregation.
I have access to a electron microscope at the University I am working through and I have examined the componets and have detailed pictures. I will compare these with pictures taken in 30 days.
Again this is what I am claiming:
No Input
No component desegregation
No heat
No toxic  or fumes of any kind
All solid state
No moving parts
Completely scaleable
As things progress I will keep you informed
vrstud
Hey Bill:
Good work.  Glad to hear that you are getting a steady output of 5.2V.  Were you able to measure the current coming out?  With that you would be able to know the power output, which is the real indicator.
Chris
JouleSeeker
Quote from: billmehess on September 13, 2011, 12:54:48 PM
No Input
No heat
All solid state
No moving parts
Yes, good, Bill -- but how about the POWER output?    when you say "scaleable" == what power output do you actually have now?
Also, any update on WHEN you will announce what this device is?
e2matrix
Congrats Bill.  Yep that's the biggy .... current on a load - inquiring minds want to know ;) .  Need to know actual power in watts being generated and then you or we can eventually guess what it may cost to build a unit with usable power.  Of course it will be a guess until all details can be worked out for a production scenario and hopefully it is one that is cheaper than solar or wind.  Of course if it can come in close in cost and runs 24/7 then it's a winner right there since neither solar or wind are 24/7.  Best of luck.
billmehess
Yes power is everything
Current numbers
I can charge a 1 farad cap to 1.2 volts in 60 seconds  e=1/2cv(2)
   (1f)(1.44)  /2 = .72 j.
.72 j/60 sec = .012 milliwatts
better than 150 micro watts.
Big improvements but still a long way to go.
