meyers vic
Started by illuminati, August 14, 2011, 09:50:47 PM
illuminati
I have been messing around with meyers vic for 8 months now, there had to be a answer, well lads its been cracked so fill ya boots.
This is a cut n paste from another site where i go under the name rizla and yet another spintronic.
It is lazely pieced together for people who have looked into meyers technology before and may find it interesting.
After building so many variations that just dont work i sat back and asked the question what is happening with meyers longitudal primary. Well mainstream science has no answer, so i dug a little deeper and uncovered the spin orbit of electrons. This creates emf in transformers, the angle of the magnetic flux affects the spin orbit of electrons and so the amount of induced emf. I was finding some answers.
Things got more interesting when i uncovered the fact that different metals have different effects when the electron orbits are manipulated by magnetic flux. In iron wire they form tiny magnets, they have a north and south pole they can attract and repel, i now have the effect meyer describes in his patents.
take a look at this site
http://www.asdn.net/asdn/electronics/spintronics.shtml
What it says is ferrous metals can have each atom give a 1 or 0 state, its a typical spintronics site, you have to look thru a lot to get the full picture.
The 1 or 0 are actually north and south poles, this is unique property of ferrous metals and it does not just apply at a nano level unless you wish to manipulate each atom individually.
First theorised around 1860 then proven in 1921 the spin orbit of electrons is where electronics meets magnetism, this science has been around a long time but not common knowledge.
I located some insulated iron based wire, after a number of experiments i found that a iron wire vic works, the mystery is over. Also the primary is not dual bi-directional longitudal wrap, it is a normal winding.
A recent test shows copper wire for the primary works but all other coils have to be a suitable ferrous wire like iron. Stainless, even 300 grade, is a poor choice due to electron scattering. Note as well the primary must be very tight and generate a uniform magnetic field (i mean a perfect uniform magnetic field) or current will leak out. A primary and secondary is all thats needed for testing to start with, this should read zero amps on a meter that measures down to 10uA with a short circuit. You can now wire in the inhibit and charge choke one at a time while checking for current leakage. If the primary is not wound correct you will notice the difference the inhibit choke makes in reduceing current while the charge choke adds more current.
So after building your vic you may well wonder why this has been such a problem, as you can see the patents have been altered and we have all been building crap that will never work, 4 years of running round in circles. Not only that but the spin orbit of electrons science has been hidden for about 80 years, it had to be suppressed or water fuel technology would be impossible to stop.
Happy days
I have just confirmed a earlier observation the iron primary induces over x2 more current than the same size copper primary. This has not been tested on a normal transformer just my vic with loose wound primary (leaky).
Heres a link for some iron wire, its not ideal but works and is cheap (about £2.50 for 40 metres). Garden wire and others like it are a bit naff.
http://www.crazywireco.co.uk/acatalog/Iron_Wires.html or the other just posted
Pure iron should give best results, but it`s a b*tch to find and when you find it the cost is £75 for 5 metres so thats simply not happening for me.
Spintronic articles relates to nano science it`s nano techno babble, with a little patience we can piece together usefull information.
Spin-polarized currents flow well in magnetic materials, but when they enter non-magnetic materials the electrons begin to lose their spin polarization in a process called spin-flip scattering.
source http://www.spintronics-info.com/technical/cold_copper_causes_spin_diffusion
comment
copper (non magnetic) does no work with the meyers vic
http://hyperphysics.phy-astr.gsu.edu/hbase/spin.html
This covers the boys that first proved the spin orbit theory
Spintronics is an advanced form of electronics that harnesses not just the electrical charge of electrons (as in conventional electronics) but also a property called spin that makes electrons act like tiny bar magnets
source  http://leebor2.741.com/spintronic.html
comment
This is the one we like
illuminati
The 8xa circuit is a variation of the vic matrix circuit it uses the same technology.
You just need to apply some basic information to build the 8xa circuit.
1) Primary flux aligns electron orbit spin in surrounding coils
2) electrons then behave as tiny magnets in ferrous metals with the correct magnetic field applied
3) the north and south poles of each atom attract to each other causeing electron clustering rather than electron flow, i do not know for certain this is how electron clustering happens but i do know it works.
lets look again at the science that makes this happen
So why not use copper wire? (non magnetic, non ferrous)
in Copper wire each atom cannot form a north or south pole so meyers stuff will not work.
The tiny magnets formed will attract or repel, opposites attract likes repel, so we can start to see how meyers transformer works, like the inhibit choke for example.
Here is a new look on meyers vic with some real science to back it up and proven to work. from this we can build his tube system 6 tube assemblys can run a 1.6l engine, The steam resonator and his injector system the complete energy solution. Without his vic none of this can be built.
TheCell
I have a Lawton pulser circuit and 2 stainless steel tubes and experimented with them long time ago. I have used bifilar wound coils on ferrite cores that really enhances gas production. But never was enough to support a motor running.
So I connect the output of my lawton pulser to the primary coil of the vic; the primary which is made of copper.
The secondary which is made of iron wire goes through a diode and than connected to the wfc? So simple?
Please draw a schematic.
I have read in the muellers thread someone using stranded wire with a iron wire in the middle an is experiencing a raise of voltage.
So your claim seems to be possible.
illuminati
Hi cell
I looked into lawton cell but dropped it, too many odd things about how its built that did`nt sound right to me.
anyways the lawton pulser should work fine, look through meyers vic matrix patent, as i have pointed out things have been altered but it gives you a good idea, the schematic is in there. Re-read carefully what i have posted (yea it`s not well presented) and understand the project you are thinking of takeing on before you start to build. What u will be putting together is four coils around a core, do you see what i have done to make the transformer work?
This is the shape your spools will look like
http://waterfuelcell.org/phpBB2/viewtopic.php?t=1267
You will need access to a lathe or 3d printer to make spools.
The primary spool is missing from the pictures.
you will need a ferrite core or a cold roll grain orientated silicon steel core should work.
i will sort out some pics to upload and put together a decent document...given some time.
yes a iron wire transformer muliplys current induced. When i wound a copper primary for my vic and compared it to the iron primary i really was`nt sure what was going on, then i confirmed it on the net. It does generate more heat tho.
Is that enough to get started on, let me know if what i have said is clear.
