Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
0 Members and 23 Guests are viewing this topic.
Overunityguide
Hi you all,
Please view my most recent video about the Negative Lenz / Delayed Lenz Effect Experiment.
It is actually a Replication of the Thane C Heins Regenerative Accelerating Generator:
http://www.youtube.com/user/overunityguide#p/a/u/0/kzxc3Ai4T3A
My results are the same as Thane C Heins. In my opinion this is what we all are looking for.
With Kind Regards,
Overunityguide
Low-Q
Quote from: Overunityguide on August 30, 2011, 04:59:41 PM
Hi you all,
With Kind Regards,
Overunityguide
Higher frequency will change the phase between current and voltage. It also affect the power output of the coil. Loading the motor will probably change the phase between current and voltage, and therfor it appears to draw less energy when loaded. Watt in a AC motor is a product of U x I x cos(phase). If the phase between voltage and current increase when loaded, you get less Watt readings from the grid.
Vidar
Overunityguide
Quote from: Low-Q on August 30, 2011, 05:41:21 PM
Vidar
@Vidar, I am familiar with the U x I X cos(phase) Power calculation... I am an electronics engineer myself. So yes I know all about shifting phases. This is exactly why I have mentioned in my video that the value which is being displayed is the real Watts Power Value. So with the cos(phi) phase shift corrected.
So to be more specific, it doesn't appears to draw less energy, but it does this for sure. You can see the exact difference when I load it with my finger. When loading it with my finger the real power consumption goes up and the cos(phi) comes closer to 1. So after this I let it run idle again and then I connect my load, so that you can see that the real consumed power is going down after connecting the load.
What happens in this setup is that we use the parasitic capacitance of the generator coil, just like Thane C Heins explains in one of its videos.
With Kind Regards, Overunityguide
neptune
@Overunityguide . Your experiments are very interesting . What happens to the input watts and RPM when you replace the lamp load with a short circuit ? There is a good reason for asking this question . In a recent news item on Peswiki News , Thane Hiens talks about a motor for bicycles . The idea is like your experiment , but uses many coils , all short circuited . The idea is that once the motor is up to speed , it will run just from the delayed Lens effect . I think Konehead mentioned the same idea on the Muller Dynamo thread .
Low-Q
Quote from: neptune on August 31, 2011, 10:37:53 AM
Did he also disconnect the powersource and ran the motor exclusivlely on delayed Lenz effect?
Vidar
