Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
0 Members and 38 Guests are viewing this topic.
ALVARO_CS
wait wait, I have to emphasize in avoiding any claim, as I said, the lack of accurate equipment may drive to inapropriate measurements. (no hurras by now please)
This is the first time I post this here (or anywhere), and not aware of related Gadgetmall accomplishments. (I miss him in the Joules thief thread)
If someone here would be interested in replicating such a setup, and make some oscope shots, THAT would be the way to confirm or deny it.
If this will be the case, I would have a pleasure in posting the physical specs  as No of turns, sizes etc.(I don`t know the flux density of my magnets from HD, neither the saturation degree of the ferrite core, from a AM radio)
cheers
synchro1
Gadget's "Piggyback Coil" video:
http://www.youtube.com/watch?v=LczzeeyfFoA
Gadget wires a tny capacitor in series with the powercoil, and generates even more power in L C tank oscillation with the rotor stopped. The series bifilar behaves the same way.
ALVARO_CS
Sinchro1: The schematic for the motor coils are at page 5 in:  http://www.totallyamped.net/adams/Coils11.swf
(I think author is Hoptoad)
The collector coils I tested were series bifilar (solenoid wind, not panckake) some 3500 turns of both wires winded in parallel connected end of A with beggining of B. - 0.2 mm enameled copper.
The driver coils: as per attached schematic /diode 1N4007 / 0.4mm enameled copper wire / 320 turns each, total 640 T / shield from a small dc motor / back: a steel washer / core diam - 10mm, x length 100mm.
MileHigh: I tried with leds and with a dc incandescent lamp 12.V - 07.A through a .1mF cap in parallel,-FBR - electrolytic cap bank.-load
As you said, small loads of leds easy to light up, but not power enough to lite the incandescent lamp.
Nevertheless, as I said in both conditions a change in the rpm should be noticed,  above all the short at the incands. lamp.
cheers
PS: guys you are so fast in posting I get always late ;D
Alvaro:
That circuit that you are using may damage your transistor.  If you notice when the transistor switches off the inductive energy gets discharged inside the transistor.
