Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
mondrasek
Quote from: Overunityguide on August 31, 2011, 03:29:46 PM
I have just tested it and it seems to be 66 Watts with the generator rotor removed, So when only running the plain motor.
@Overunityguide, did you remover the generator ROTOR or the coil?
Thanks,
M.
Overunityguide
Quote from: mondrasek on August 31, 2011, 04:53:49 PM
Thanks,
M.
@mondrasek
I have removed the generator rotor, so the shaft only was turning.
With Kind Regards, Overunityguide
sinergicus
If  the magnets on the rotor will  have,all,the same poles up ,will be the accelerating effect present also?
Mike Sliver
Hello,
I am a lurker here,rarely comment. Now you mentioned shorting the coils. And I am thinking  what someone else has done with a ubolt and two coils and connects the coils to a battery and the expected electromagnetic effect of it being able to pickup a metal bars is evident, but when he disconnects the electric source the coils stay energized and are still able to pickup a steel bar after being disconnected from the energy source. See Ed Leedskalnin Magnetic current pt2  on you tube.  http://www.youtube.com/watch?v=9z3z1sftowg
I have seen others replicate this and Iam wondering if shorting the coils has a similar effect of storing energy. Now if this has been mentioned before. excuse me. Mike Sliver
Overunityguide
Quote from: Mike Sliver on August 31, 2011, 11:31:22 PM
Hello,
Hi Mike
There is a difference between magnetic soft and magnetic hard iron coil cores. I am using a normal bolt as a core. So I don't think that what you say is taking place in this setup, what I think that takes place in my setup is the so called delayed Lenz / negative Lenz effect.
For the Theoretical Explanation Concerning this Effect Please look at the Following Link:
http://www.youtube.com/user/ThaneCHeins#p/u/0/Z1weXYivARo
Which is provided by Thane C Heins
http://www.youtube.com/watch?v=kzxc3Ai4T3A
