Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
Overunityguide
Quote from: teslaalset on September 03, 2011, 01:08:09 PM
Can I ask you for a calibration measurement?
What is the actual power consumed when the whole coil setup is removed?
@teslaalset,
Please see my previous posts, there you will find your answers...
And before calling it a very misleading experiment...
Please keep in mind: My video is only showing 'proof of principle'
Kind Regards, Overunityguide
Overunityguide
I have done a second Video about the:
Delayed Lenz / Negative Lenz Effect for now:
The Difference Between Shorting and Loading
In which I show and clarify how you can get the regenerative acceleration effect when you Short your Generator Coil or when you try to Load your Generator Coil
So if you have any time left, here you can find it:
Delayed Lenz / Negative Lenz Effect, Difference Between Shorting and Loading
http://www.youtube.com/watch?v=lGstOJ4NDQQ
With Kind Regards, Overunityguide
teslaalset
Quote from: Overunityguide on September 04, 2011, 05:05:45 PM
I am not suggesting you are possibly misleading, but when not correctly interpreted, your (and Thane's) setup could suggest this way OU is possible, although you're not speaking this out loud.
Shorting coils has been discussed here and at other fora quite often and some members think it's the holy grail to OU.
You're experiment + data shows it's not as simple as that.
I missed the earlier post on the data without coil, I got it now.
The numbers are even worse than I thought.
9 W loss because of the coil setup, max 2 W gain when loaded with LEDS.
Thanks for sharing this.
kEhYo77
Quote from: teslaalset on September 04, 2011, 05:33:21 PM
One has to remember that when full setup of coils would be implemented the drag will be much less and power required
to drive the rotor as well. All that he has to do is to place ODD number of those HV coils around the EVEN number of magnets rotor...
Poit
75watts to run the generator
the led's probably consume 2 watts...
ok so its negative lenz effect, so it now consumes 72 watts or so.... but is the effect the same when you put a larger load on it? what happens if you put something that requires say 80watts? is it going to be 70watts in and 80watts out?
