Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
gotoluc
Quote from: CRANKYpants on October 24, 2011, 02:30:48 PM
Electronic meters display the energy used on an LCD or LED display, and can also transmit readings to remote places. In addition to measuring energy used, electronic meters can also record other parameters of the load and supply such as maximum demand, power factor and reactive power used etc. They can also support time-of-day billing, for example, recording the amount of energy used during on-peak and off-peak hours.
Hi Thane,
thanks for doing all the full power calculations.
In the case the Utility Company would start charging for Reactive Power. Would that be for the 1.97 Watts used?
Just wondering :-\
Luc
CRANKYpants
Quote from: gotoluc on October 24, 2011, 03:18:51 PM
Hi Thane,
In the case the Utility Company would start charging for Reactive Power, would that be for the 1.97 Watts used?
Just wondering :-\
Luc
PROBABLY MORE LIKE (147.4 x 0.9) - 133.1 = 14.3 WATTS  :'( GIVE OR TAKE.
BUT IF YOU FOLLOW MY INSTRUCTIONS ABOVE YOU'LL BE ABLE TO POWER YOUR ELECTRIC SAIL BOAT ALL THE WAY TO AFRICA AND BACK WITH ONLY TWO BATTARIES.
CHEERS
T
gotoluc
Quote from: CRANKYpants on October 24, 2011, 03:26:31 PM
PROBABLY MORE LIKE 147.4 x 0.9 = 132 WATTS  :'( GIVE OR TAKE.
CHEERS
T
Wow :o... that's a rip off.
I'll get the H-Bridge out and make my own Power.
Will update in a couple of days
Luc
wings
Quote from: CRANKYpants on October 24, 2011, 03:08:48 PM
NOW ALL LUC HAS TO DO IS:
1) TAKE A BATTERY INVERT THE OUTPUT TO AC
2) RUN IT THROUGH HIS "SIDEWAYS" TRANSFORMER
3) BUMP IT UP BY 500%
4) RECTIFY IT
5) FEED THE OUTPUT INTO ANOTHER BATTERY AT 5 TIMES THE 1ST BATTERY INPUT
6) RUN LIKE HELL... 8)
T
driving form zero to 16 KHz (with Arduino)
http://interface.khm.de/index.php/lab/experiments/arduino-dds-sinewave-generator/
this circuit in pure sinusoidal way
http://www.kerrywong.com/2010/03/12/a-power-inverter-with-arduino-pulse-source/
or use PWM ?
or other resonant circuit?
futuristic
I bought this for arduino to make DIY signal generator:
http://iteadstudio.com/store/index.php?main_page=product_info&cPath=18&products_id=414
But I don't know how to amplify the signal to get something in the range 20V 3A AC. Probably something like powerful audio amplifier?
