Confirming the Delayed Lenz Effect
Started by Overunityguide, August 30, 2011, 04:59:41 PM
synchro1
A large 4" diametric magnet spinner with perhaps eight magnet core output coils could attach to an A.C. induction moter at the axel. The motor could run the spinner up to threshold speed, then after the output coils began to power the spinner, a shunt could turn the motor into a powerful A.C. alternator. All the coils and the alternator could tie into the same rectifier, and maybe charge a large D.C. battery bank. This would generate kilowatts of free energy!
Newton II
Quote from: synchro1 on March 01, 2013, 10:07:33 PM
When you convert the motor into powerful AC alternator,  it (alternator) will produce powerful lenz's forces which inturn will slowdown your spinner.  Even if your spinner rotates at 50k,  it will not have enough torque to overcome strong lenz's forces.   Eventually your spinner will stop.
Build the machine and see.   Then you will know the exact practical problems.
vineet_kiran
A large 4" diametric magnet spinner with perhaps eight magnet core output coils ....
When you use a large diametric magnet,  you may get powerful torque at the center of the magnet.   But I don't think you will be able to achieve OU in single stage.  You may have to do it  in several stages.
synchro1
Quote from: vineet_kiran on March 02, 2013, 07:41:25 AM
The alternator acts as a torque converter, and governor, like balls on a steam engine and has a hydrolic clutch. The spinner R.P.M. is controled by charging the alternator windings, to best run it in resonance.
DreamThinkBuild
Hi Synchro,
There is a patent that I thought was pretty clever, you might be able to try with your spinning magnet.
US8120225 - External split field generator
http://www.google.com/patents/US8120225
The patent shows how to use a spinning diametric or other magnet near the center of a coil to aid an already established flux path. I'm not sure how Lenz will effect the spinning magnet as it is 90 degrees to the coil and positioned at the coils bloch wall. Something to look into maybe.
