Pyramid healing Tent
Started by tetrahedron, September 09, 2011, 11:37:48 PM
bbbaty
Hi Mike,
I think that seeds essentially need energy to break through the hull of the seed pod and the pyramid supplies extra energy that helps the plant burst through. The energy will actually extend the longevity and production of plants(animals too).  It seems that any biological activity such as growing, fighting off disease, reproducing, etc. requires energy and a pyramid can help supply that energy faster and more abundant than the normal biological path.
The taste of foods that have been energized by the pyramid is phenomenal. Have you ever bitten into a peach or another piece of fruit that was just outrageously sweet and good, better than the rest? Well, the pyramid makes just about everything placed in it that tasty. I got to where I almost exclusively ate from the pyramid as other foods just weren't very tasty.
The pyramid needs to be oriented with the earth's magnetic gauss running through the face and not corner to corner.
I read a convincing study regarding magnetic declination produced by 19th century Brits. They had access to hundreds of years of compass readings and determined that the magnetic pole travels around in a circle. The north polar area is a "basin" rather than a point and due to the earth's spin and wobble the magnetic pole continually moves around of the lip of the basin. This is because the magnetic pole must coincide with the geographical high point. This wondering magnetic pole won't veer off enough to misalign most of the ancient pyramids, particularly ones in equatorial zones.
I have doubts about anything ever happening with a solar flare. Every several months for the past twenty years people have been predicting a destructive flare but it never happens. I mistrust a lot of science as well as pseudo-science. They pile theory on top of assumption, on top of speculation, on top of more theory and build up a scenario that hits the mainstream as if it were real. Then when a non armchair scientist does some actual experimentation, peoples minds are blown because their original assumptions fail as they were not based on reality.
Are you interested in building a pyramid? What altitude do you live in?
All the best,
pg46
Hello all-
I would like to jump in on this one with my 2 bits worth.
I have built some pyramids to experiment with and much to my complete bewilderment they worked ! Well that is to say that they had a profound effect on some materials placed in the pyramids compared to the controls outside of the pyramids.
My first pyramid was a hastily assembled cardboard one about 10 inches high at the center and made to the dimensions of the Great Pyramid at Giza. Luckily for me I was near the equator at the time and the magnetic deflection there was only less then one degree difference from true north to magnetic north. This eliminated the problem of having to decide which north to go to since as you may know there is often a debate about whether one should align a pyramid to magnetic north or to true north. My experience and research since then would indicate that magnetic north is the correct one however.
Food items placed inside a pyramid do indeed taste better! Sweet things like fruit become sweeter and fruit juices such as orange juice loose their acidic taste and become much smoother. I've conducted blind taste tests with different people and they always choose the pyramid sample item as being the best tasting. While these things are amazing in of themselves they are still subjective so my favorite demonstration item is using milk samples.
Milk is great material for testing because as we all have experienced at one time or another the stuff goes bad quickly if left out of the fridge too long. In my experiment setup I bought fresh pasteurized milk from the market and placed the milk into two identical sterilized glass containers in equal amounts. Sample one was placed inside the cardoard pyramid model and the control sample was placed inside a square box of the same construction methods and materials.  They were place in the same room about 10 ft apart from each other. The temperature at that time was quite warm at around a consistent 28 C.  Both the pyramid model and the control model had holes cut into one of the sides about 4"x 4" so that we could view the insides and also to ease taking the samples in and out without having to disturb the models by lifting the forms.
The results were as such, after 24 hrs the sample in the square box(control) was beginning to go sour while the one in the pyramid looked OK. After 48 hrs the control sample had to be tossed out as the odor was quite foul by this time along with it having brown discoloration. The pyramid sample still looked bright white and smelled OK while it was now beginning to thicken up too.
After day 4 the pyramid milk sample was still bright white and quite shiny and had gelled up to something like the consistency of yogurt. On day five I got brave and tasted it. It was great! I ate it all up happily as it tasted so delicious and surprisingly sweet. No stomach disturbances or anything negative, just happiness.
Every so often I repeat this experiment to demonstrate to non believers, always getting the same result. I have tried plastic material and at different dimensions(taller pyramids) but those have so far failed. I am not saying that plastic and/or taller pyramids won't work but for me they have not. When I revert to using cardboard or (thick paper) at the giza pyramid dimensions then it works again. I have only used magnetic north and so can't comment on the possible use of other compass directions.
Some say that plastic is OK but others say not claiming that static electricity can build up along it's surface thus negating any positive effects. So far I have not had success with plastic myself.  Some say using metal materials such as copper or aluminum is good. Both of these materials are non magnetic which is essential otherwise the lining up to magnetic north will not work as most metals react strongly with magnetic fields, iron being a good example of this. There are many claiming copper to be beneficial while there are lots of warnings about using aluminum. Aluminum in general is not considered to be beneficial for the human body system so should probably be avoided.
Pyramids sometimes take time off and temporarily stops working and no one knows for certain why. They say that the weather, solar flares,  and the moon cycles can effect pyramid function. If you find an experiment not going as hoped then just be patient and you will certainly be rewarded with good results soon.
I haven't yet experimented with growth rates of seedlings or plants but will look forward to trying it out sometime. I can say for sure that milk stays fresh longer while in a pyramid and will turn into some delicious yogurt like product after a few days.
It's amazing that a shape worth a few cents made from cardboard can have such an effect on an item. Anyone (including the famous "Mythbusters")who says pyramids don't work either haven't tried it or haven't conducted the experiments properly.
Pyramids have a life enhancing energy, no doubt about it.
try one out !
cheers,
PG
MasterKayyy
Im thinkin about building one out of copper but how would i go about building it to the specific dimensions, im thinking of building atleast a 4 foot one something i can meditate in and experiment with the plants as well. any info or links would be great!! thanks! - Kay
Free-Dom
hi guys,
thats a very interesting forum - unfortunately it hasn't much activity...
I also want to build such a nice pyramid. But I havn't really a plan how to do that...
I thought of making one of wood. What do you think about it?
Hope someone replies
Thanks! Free-Dom
mp
bbbaty, I hope you are still connected to this thread as I am interested in what proportions you used in constructing your pyramids. I found this page researching Ed Leedskalnin. Ed built the Coral Castle in Florida but before that, he apparently healed himself of advanced tuberculosis by constructing a pyramid in which he sat within in the afternoon sun (and followed the sun's path seated on a swivel chair). My understanding that he is the only one to date to survive this stage of the disease. BTW, for those interested, I believe Ed used scraps of wood to build his but that is all I know about it.
