Ibpointless2 Crystal Cells
triffid
I got some wood and a rock to test as electrodes soaked with tap water.this is what I got
.010 volts for the wet wood and wet rock on a wet sponge
.020 volts for wet wood and copperplated nail
.042 volts for wet wood and soda can pull tab(aluminum).
What I did not expect was to get voltages from the wet wood all by itself,just placing the two voltmeter probes (in different spots) on the same piece of wet wood gave me voltages.It jumped around a lot but the highest voltage I saw was .072 volts.
I picked up a piece of wood that was rotting on the ground.It came from a tree.
The rock was nearby.
triffid
I got two pot scrubbers and they are copper plated.And some oxalic acid in a can of "bar keepers friend".It turns rust into a form that is transparent.So when you scrub a rusty spot with it it looks like it vanishes.But what really happens is its still there,just transparent.triffid
triffid
http://en.wikipedia.org/wiki/Oxalic_acid  It says that oxalic acid is 3000 times stronger than acetic acid.And can be found in black tea too.
triffid
triffid
Oxalic acid's main applications include cleaning or bleaching, especially for the removal of rust (iron complexing agent), e.g. Bar Keepers Friend is an example of a household cleaner containing oxalic acid. About 25% of produced oxalic acid is used as a mordant in dyeing processes. It is used in bleaches, especially for pulpwood. It is also used in baking powder.
triffid
Maybe baking powder would be better to use in our cells since oxalic acid is 3000 times stronger than acetic acid?Baking powder and black tea?
gives me oxalic acid and tannic acid.triffid
