Ibpointless2 Crystal Cells
0 Members and 1324 Guests are viewing this topic.
triffid
I like the idea of wrapping a leaf around an electrode.But not one with oxalic acid in it.That stuff is 3000 times stronger than acetic acid.
I do like the idea of using petro jelly and wrapping paper around that.Before when I tried it the stuff (petro jelly).It got scraped off when I stuck the magnesium electrodes into the gluey mass.I got two more empty egg cartons today.And will try this weekend to get some pictures  of some of my early cells.So I can post the pictures here.triffid
I will build six more cells with dandelion leaf tomorrow.
triffid
I built six more cells with dandelion leaf today.I had left the six magnesium strips overnight in petro jelly and wrapped four of them with napkin paper before sticking them in the gluey mass.I used a q-tip to make a hole in the gluey mass for the last two magnesium strips.Two different construction methods.I also used double epsom salts.triffid
triffid
I have been wanting to use aluminum wire and copper wire for some time now.So I twisted the tops of five pieces of copper wire with the tops of five pieces of aluminum wire.Together to make five connected bridges between cells.Then I used a tiny amount of oxalic acid from barkeepers friend in each cell.Thus I made six more cells using copper and aluminum wires as electrodes.I used double amounts of epsom salts here too.
I tried to solder the pieces together but they kept falling apart on me.
triffid
triffid
There were holes in the plastic egg cartons.I had to tape those up before I could put glue in them.triffid
PhiChaser
Hey all,
I left a cell that I made on the 20th (with borax) connected overnight to two 6v batteries in series charging the cell in parallel so it got 'charged' with about 10.5v overnight. (Yeah, my batteries are running down, no pun intended!) As expected the cell did not charge up over the 3v range, although it did read a pretty solid 2.75v when I unhooked it and took measurements a little while ago. The VOM drop is FAST to below three volts... (Where do those extra 7+ volts go? Back to the batteries? To ground somehow?). Maybe I need to try and 'charge' the cells with HUNDREDS of volts so that they will retain more. Somehow I doubt this will help... Probably start a fire or something...  ???
The cells I made with borax and charged on the 19th and 20th (a few days ago) are still holding their voltages over 1.5v. This is good! :)
Oh, I was able to charge up the same (overnight) cell from below 0.4v (around 0.3v) to over 2.0v in less than 10 minutes yesterday. Also I was able to get about a tenth of a volt (0.10v) on the VOM at the SAME TIME I tested the amperage at about 350uA (0.35mA). The best readings I had previously were significantly lower (0.01-0.02v range) with WAY lower amps. My poor meter! I pegged that thing hard a few times... It looks like the 1mA meter I have doesn't work so I get to use either the 0-500uA meter (that is too low sometimes and pegs) or the 0-2mA meter (which is currently (heh heh) a bit high but hopefully will be too low eventually)... I have a lot of things to do today but hopefully I will find enough leftover supplies picking up my workspace to mix a few new cells. Will update later...
Happy experimenting,
PC
