Ibpointless2 Crystal Cells
triffid
How to clean silver without harsh chemicals!  http://www.ehow.com/how_4507216_clean-silver-coins-chemicals.html
I believe its useful here.triffid
triffid
Warp drive using casimir plates as the source for energy.   http://www.guardian.co.uk/science/2001/jan/07/spaceexploration.theobserver
triffid
http://en.wikipedia.org/wiki/Casimir_effect
Because the strength of the force falls off rapidly with distance, it is only measurable when the distance between the objects is extremely small. On a submicron scale, this force becomes so strong that it becomes the dominant force between uncharged conductors. In fact, at separations of 10 nmâ€"about 100 times the typical size of an atomâ€"the Casimir effect produces the equivalent of 1 atmosphere of pressure (101.325 kPa), the precise value depending on surface geometry and other factors.
triffid
Faster than light travel?Due to casimir forces? http://www.daviddarling.info/encyclopedia/C/Casimir.html triffid
Interesting website.
triffid
Want meteorites for electrodes?Heres a pack of three of them.  http://store.space.com/memorabilia-collectables/meteorite-3-pack/
triffid
http://www.livescience.com is another interesting website.
PhiChaser
Quote from: triffid on May 29, 2012, 01:30:25 PM
triffid
Thanks for the links triffid! Powdered meteorite for an additive, hmm... I didn't look, how much did they cost? And how would you know you weren't getting just a some sort of regular rock? Those tubes lightning bolts make when they strike earth/sand would be something else along those lines...
I would get some 'interesting' looks from my woman if I started buying meteorites heh heh...
I'm still reading around a volt from one of the last cells I charged (that 'popped' open). It is the one that has the dark grey (oxidation?) on the Al but maybe that is just on the surface. I will measure it later today (if I remember). I also need to spend some time reading through the JT thread (and the ringer thread probably...) since that is on the list for upcoming projects. :)
Happy experimenting,
PC
