Ibpointless2 Crystal Cells
triffid
I believe this next material has good application in our crystal cells.   http://en.wikipedia.org/wiki/Melanin
The photochemical properties of melanin make it an excellent photoprotectant. This is because it efficiently absorbs harmful UV-radiation (ultraviolet) and transforms the energy into harmless heat.[3][4][5] This occurs by means of a process called "ultrafast internal conversion". This property enables melanin to dissipate more than 99.9% of the absorbed UV radiation as heat[6] (see photoprotection). This prevents the indirect DNA damage that is responsible for the formation of malignant melanoma and other skin cancers.
In other words it turns UV into heat.Not a bad trick at all.
triffid
I would use plant melanins from sliced bits of apple.Not bananas.triffid
triffid
Ok,the new calcium oxalate (black pepper) cells are a week old and the untreated magnesium strips are still strong.One magnesium strip in the last dandelion leaf (oxalic acid) cells has broken completely in half.This is only with slight handling.Those cells are as of today three weeks old.I reported on their voltages and amps yesterday.In the beginning they were the same,with the black pepper cells losing as of yesterday.I did see some black color forming on the untreated magnesium strips.But it seemed to have stopped after a couple of days.
The borax treatment of the magnesium strips did not stop their breaking in half.The oxalic cells maintained a good voltage to the end.
triffid
triffid
Ok,after a week and four days the first magnesium strip snapped in half on the black pepper cells I made.So the calcium oxalate is too strong for bare magnesium metal.The only good news here is I did not have to wait until thursday to find out.Today is monday.I was able to bypass the damaged cell and lit a red LED with the remaining 5 cells hooked up in series.Dim but its lit.So the magnesium strips slowly break one by one???
So now I may try what big J suggested and add dry borax to my next batch of dandelion cells.To see if that keeps the magnesium strips treated with borax from snapping in half.He said the added borax should keep them repaired.No more black pepper for me for now.Low power plus the magnesium is not protected.
triffid
