Ibpointless2 Crystal Cells
triffid
I'm still working on a JT and having no luck.Except bad luck!triffid
I made my third one today.
So same neg results
so bad circuit design?
bad wire?
Bad coil winding?
Bad circuit most likely?
then coil winding?
bad wire unlikely?
triffid
http://www.youtube.com/watch?v=gTAqGKt64WM  My circuit I chose for a joule thief.I did not wind my coil the same way.Nor has it been soldered the same way.triffid
triffid
Been busy the last fews days with other stuff(heat wave here in st.louis).Heres something interesting about heavy water
http://www.popsci.com/diy/article/2006-07/ice-capades  .Normal water is slightly radioactive anyway and KaCl is slightly radioactive too.
Just your local neighborhood isotope supplier. http://unitednuclear.com/.
triffid
triffid
Hi All, I finally made my JT work.I used the circuit shown here,  http://www.youtube.com/watch?v=gTAqGKt64WM.  They also showed me that I was soldering together the wrong two wires coming off of the ferrite core.So I solder together the two wires together they showed and now it works!!!triffid
