Ibpointless2 Crystal Cells
triffid
Here is a picture of my magnesium strip battery with carbon soot from a butane bic lighter.
triffid
Here is a voltage reading  caught at .009 volts.It was jumping around a lot.
triffid
IB2,thanks for the suggestion.I will consider it more when I get home.I had to make a 60 mile trip to get these pictures.triffid
triffid
I do think that the source of carbon and how you put it on the magnesium is important.My brother tried to help me yesterday by dipping two extra strips I had with me into molten candle wax and burning it off directly from the magnesium strips.Once the soot formed and the strip cooled down.I tried to see if I had voltage but I had none.When I get the time and the desire I will conduct more experiments with carbon.I am not my brother so I think he did it wrong.I would not dip it in wax at all.I would put the magnesium strip in the yellow part of the flame and deposit the carbon from the smoke directly on the metal.triffid
triffid
I am having a problem here.I am now suspecting my earlier readings of .6 volts and .003 mAs to be in error.I now believe I was touching the strip with my hand somehow becoming part of the circuit.I can get readings of .016 volts max without touching the strip at all.Just like the picture showing .009 volts.I was trying to make some new carbon coated magnesium strips today and was getting a max of .48 volts but I was touching the strip but without touching I get about .007 volts.I was touching the strip holding it with one hand and using the voltmeter probes on the strip itself.If I hold the magnesium strip like an antenna then I get increased voltages.Like ten times the voltage it appears..So I must say now that the higher volt readings are in error.When the magnesium strips are placed on a plastic lid none of them show a voltage until I get to the new carbon coated one.Then I can get .007 volts.The two my brother burned the wax on,one with just the borax treatment by itself show no voltage at all sitting on the plastic lid.If I hold them in my hand then I get voltages up to .48 volts this morning.triffid
