Ibpointless2 Crystal Cells
0 Members and 28 Guests are viewing this topic.
NickZ
  It may not make sense but it is caused by the fact that the ground and neutral lines inside the house run parallel to the positive AC lines and do transfer some juice by induction or capacitance to the ground lines. This type of energy can travel across surfaces, like tables, tile floors, etz...  All it takes to test it is to turn off the house breakers.  I was trying to make that dim led light up brighter, on just one wire connection, by using coils and inductors, but I have not been able to, yet.  In anycase, I'm looking for the real ambient pulse and not the AC or Fm frequency sources. It is as illusive as it gets,  but it was fun playing with that effect, and is good training for the real thing.
jbignes5
Well it's funny that I have a lamp right next to it and when I switch it on it degrades the ac signal or dampens it. Weird.. It's doesn't make any sense. Our Ac system is somehow interfering with whatever these things are receiving. Hmm.. I turn the light off and the signal gets stronger or more pronounced. I might have to check the ground of the scope to make sure I am not getting slight hums from anything else. I'll have to smooth it out with a capacitor or something like that.
Also if I disconnect the voltage meter the led gets brighter.. Hmmm... So we can't measure the device for some reason. Well not with regular devices.
NickZ
 You need to make an AV plug to really see the effects. I connect one ground wire (outside earth ground) to one side of the AV plug, and go touch this and that...
  You'll see what I mean if you turn off the house breakers, the dim led on the 5 cells will go out.
  I wanted to combine the cells input along with the ground input, to see if I can make the dim led get brighter, but it was like adding water to oil, and I could not get them to add up. Two different incompatible frequencies.  I'm just learning about this stuff, but the trick is to tap the right natural frequency and not just  the man made ones, as those can all stop working and fail, at any time. If the natural frequencies fail, it's time to look for a better place to live.
ibpointless2
Guys its normal to see a AC voltage on a cell, A digital meters do this. Even hooking a AA battery up to a digital meter to read its AC voltage will show almost double the voltage than a DC voltage. But swap the polarity on the AC meter and you'll get no voltage, if it was truly AC voltage then you would get a voltage even when you switch the polarity. Hooking any type of diode to the cell will have it affected by the electromagnetic radiation that's in the house.
jbignes5
Quote from: ibpointless2 on November 30, 2011, 02:42:15 PM
But why is there a signal. I can also see a signal on my scope. it is around 100k a second and they are pulses I see them in the range of 10 uS on the scope. That is micro seconds. The funny thing is I don't see this on the carbon battery nick. The signal is flat. But when I added it to the other batteries it did boost the led brightness. So maybe they are the stronger heavy current types.
The carbon I am using is not the right kind. I'm thinking it will need the quartz to boost the voltage. It should be like the more you use it the better it conducts. I am starting to understand why you asked me about the water. You want the little crystals from the shavings. After I cut the carbon up I mushed it till it got like graphite power. It is still everywhere! Rofl...
I was thinking we could print these out? Then stack them together around the center electrode. then insert them into a carbon lined container? Having every other layers smaller and bigger will allow for better staying power. Remember wave guides that whistle in the wind. The wind in this case is polarized charges flowing trough the aluminum or magnesium and into the carbon. The vacuum of current causes a flow into itself and around the center electrode. If we put the crystal layers in the way they will vibrate like the dickens giving us plenty of voltage. The good thing is this carbon is like an ink when you use water or maybe the stuff in ink? Like mineral oil? Linseed oil?
The crystals you are gonna want dry but stuck together maybe ceramics?
