Ibpointless2 Crystal Cells
0 Members and 25 Guests are viewing this topic.
ibpointless2
triffid
Dont know if this was already posted in this thread but I wanted to park it somwhere on overunity and to annouce I will be building some glue power cells myself and am pleased that others here got them to work. http://www.bing.com/videos/search?q=john+hutchinson&view=detail&mid=1DFAAD8FAA73F0AEFA561DFAAD8FAA73F0AEFA56&first=0&FORM=LKVR16
triffid
ibpointless2
Quote from: triffid on January 01, 2012, 09:44:37 PM
triffid
I look forward to what you build. The best cell I've made was Elmer's glue, Epsom salt, and salt substitute. I found using copper and magnesium for electrodes works best.  :)
triffid
I have the first one built.It will have to dry .And I have to get a voltmeter from somewhere.The blob has a two inch stainless steel screw in it and a two inch copper wire in it.On a piece of square paper cut from a paper plate that was going into the trash anyway.I just found out over the weekend that john open sourced his crystal battery technology.I was wondering if ordinary table salt did the trick also?Its sodium chloride
with a trace of iodine.We may not want that??Iodine anyway.So are we wanting surface area first?With the metals?  triffid
ibpointless2
Quote from: triffid on January 01, 2012, 10:57:04 PM
Table salt is bad stay away from it. Stick with salt substitute because it has Potassium chloride in it. John Hutchinson cells are not what they seem. Johns cells voltages will die off if no water is given to them. The trick is to create a cell that keeps it voltage even when dry. If a cell needs water to keep its voltage up than its more than likely galvanic, and galvanic batteries die after awhile.
