Ibpointless2 Crystal Cells
triffid
I got the nu-salt at a grocery store named Schnucks. Theres a big chain of them here in st.Louis,mo..My control is holding at about .011 volts.My control is just mortons salt sub and elmers glue- all, copper and aluminum wires.triffid
triffid
IB2,when you did your video on squeezing your big blue cell to get more amps.Did you get some idea of your voltages?Did you get about 80 volts out of it when you were at your max amperage?triffid
I no longer think that atmospheric pressure is responsible,Just quantum pressure.
triffid
I do think that all vibrations help to jiggle these casimir plates so higher temps making more power is not a complete shock to me.Maybe air pressure helps a little but not as much as I thought in the beginning.triffid
triffid
So now its been 70 hours(almost three days) since I made my last two cells.My voltages from my latest two cells are  .10 and .003 volts.These are the two cells I made with morton Salt sub.Yesterday they were reading .4 and .33 volts.So I don't know what to think right now.The tin can lid cell I made with a copper plated disk is steady at .015 volts.That the one I never stirred.So far my cells are not producing the voltages they are supposed to produce so what gives?My magnesium is not here yet.Yesterday was a day of rain but they were inside and the weather the last two or three days has been cold.I have been warm enough inside the house for me anyway.I will have to spend some time thinking about this.triffid
ibpointless2
Quote from: triffid on January 18, 2012, 11:08:32 AM
Are you sure you're using the correct glue, Elmer's Glue-all not school glue. If you can post pictures of the cells and how you make them would be helpful.
Are you adding the salt substitute and Epsom salt together when you mix it into the glue? If your just using Salt substitute than the cell will never work, you must add salt substitute and Epsom salt together into the glue.
How about taking a strip of paper and getting it wet and rubbing salt substitute and Epsom salt into the paper, wrap the paper around you copper and aluminum wires making sure the metals don't touch. Allow the cell to dry overnight and it should around 400mV. This cell eliminates the Glue factor and this cells should work.
I find it odd that the cells are not working for you, we will get them working for you but I need at least some pictures or videos of what you're doing; a picture is worth a 1000 words.
