Ibpointless2 Crystal Cells
b_rads
Ibpointless2:
You mentioned earlier about finding rocks to serve as the negative terminal for a cell.  While goofing around in the shop, I performed a quick setup to test your idea.  In a small dish coiled on the bottom was stranded copper wire.  Powdered aquarium carbon on top of the copper wire and felt on top of the carbon and added water.  Here is what I found when applying slight pressure.
Magnesium    1.8 to 1.92 volts
Zinc             1.1 to 1.3 volts
Fools Gold - Iron Pyrite  0.01 to 0.03 volts
Yard Rock     0.35 volts
Antimony      0.45 to 0.5 volts
Lead Sinker   0.55 to 0.6 volts
Hope this helps.
Brad S
triffid
B_rads,What did that yard rock like?Was it flint or just regular rock?Did you add any water to your setup?Was the aquarium charcoal wet or dry?Or was it straight out of the box?IB2,Its not impossible to get pictures.I did not like t-mobile selling me a phone that was lacking in service.The salesman almost grinned about it it seemed.He did try to send the picture but it was held up.And i recalled later that it was to a couple of friends on the phone that I had a very hard time sending a pic to.Not to my email account.Just a tough lesson to learn in the school of hard knocks.There are some net 10 phones at the local family dollar that have cameras.I will be checking them out in the next couple of days.I had net 10 but had no camera in my first phone with them.This store also sells the 50 dollar a month unlimited plan that I can use.
triffid
triffid
Brad,never mind that one question.I see you added water to your setup.thanks for the info.triffid
triffid
53 hours since my last batch of glue power cells were made.  1.19 volts and .89 volts for the mg/copper cells.They are jittery still but those were the top two voltages for them.My tin can lid cells are not so jittery.the one with copper plated zinc disk is still reading steady at .31 volts and the last two tin can lid cells with mg strips on top of them are producing .98 volts and .84 volts.If I have these same voltages tomorrow.Then
1) morton salt sub is the one to use.
2)I will make more tin can lid cells to put into a panel.
I wonder since the crystals are so fragile would a light dose of hairspray keep them intact?
triffid
triffid
I think I will use about 20 cells for my first panel.20 times .89 volts =17.8 volts.It would be enough volts to keep a 12 volt car battery topped off.With a blocking diode to keep the battery from running power through the panel.Its how I had my solar panels set up in texas.For eight years.I can run some leds and a radio off of this setup.
i have been thinking about the use of water to recharge some of these batteries.Its not such a bad thing to add a little and extract power from zero point energy for the next three days or longer.I posted a link to a video where the guy recycles the water by having everything inside a 2 liter bottle. And gives it a shake once every few days.I know to avoid water for my cells.But Im not talking about my cells.
What if one one way mankind can get energy from the vacuum is though using water?No need to break it down into oxygen and hydrogen to burn it?Not to get direct electricity from zero point?triffid
