Ibpointless2 Crystal Cells
triffid
NickZ those are good looking batteries.I guess I will plead insanity now.I know these cells have no current.Moray found a way to draw more out of them.I need to park this here so I can refer back to it .Just a very simple way to plate copper or nickle.   http://www.youtube.com/watch?v=Q8Xo43sfLgY&feature=related  .I checked out my beach today.I can only get to it by climbing down a 40 foot hill.I guess I will wait for warmer weather to explore it.triffid
NickZ
 triffid:
   Just thought that I'd save you some time. You may be able to get to where you say to want to go by using oscillators with your cells, to help charge batteries. They will help to add voltage to batteries, but not much current.  The trick is in finding the oscillator circuit that will work, using hardly no current. Not that easy... but don't give up.
  I don't recommend making the cement cells anymore as they have high impedance, and will drop in voltage after a while, like most other cells will also.
On the other hand they are a year old and still lighting leds.
triffid
One of the things I plan to do is to put my finished panel on an oscilloscope to look at the ac component of this current if there is any.If theres AC then how can these batteries act as a diode?If an AC current gets through?Diodes block AC by definition.So if any AC gets through its not a diode.I had solar panels hooked up to a car battery in a corner of my house in Texas.I made some electricity for eight years.I was still hooked up to the grid.So I had both.The truth is most likely it will take another 100 years to make these crystal batteries more powerful and much smaller than what you or I could do today.But when they catch on the human race will be taking them to other star systems in the starships to come.By then money and research will have changed them into power sources.That we can be proud of.Proud that we played a small part.It only takes one person to make a difference.Luther Burbank feeds the world today with the Russet potato.A mutation he spotted and kept alive when others would have walked away.I read a book on him once.He even developed a spineless catus that cattle could eat.triffid
triffid
Im not really set up to melt anything or heat anything on the stove.I do have a hotplate.I could glue stuff together.I will be using aluminum duct tape to connect my cells together.A trick that another researcher has already done.I am in the process of getting enough tin can lids together.Not all tin can lids are conductive anymore.Most of them seem to have a thin layer of plastic on them anymore?triffid
triffid
If I had 2000 of these cells hooked up in series that would give me 1500 volts.What can a guy do with 1500 volts and very little current?
just a question?He could separate water into hydrogen and oxygen without drawing much current or any current if I understand that Stan Meyers was correct in his knowledge in the operation of his water cell? triffid
