Ibpointless2 Crystal Cells
triffid
Thanks everyone for your input.I do appreciate it. I stumble around a lot when it comes to doing things.What I noticed on my panel sunday was the cardboard was wet so maybe the cells are not electrically isolated until it dries more?If epson salts is the key factor here Im sure it has a brother or sister crystal material that could be tried?I will study your comments more.I do better sometimes taking a break from a task.I see these things now like fuzzy balls of energy(separation of charge,more of a static charge type thing).I can let my panel dry a little more and try to study other peoples video clips for now.triffid
triffid
Once again my tin can lid cells/mg are still working with .9 and .8 volts.My beef with them is I have to eat a lot of canned pineapple to get the tin can lids to work with.These are the cells I do not have to stir.
The suggestion to cut out the good cells is a good one.I think I have three good cells at least.If I need ten to light an led then then i might not be able to do it without making another panel.
Epsom salts seems to be the best water though. This is because it is crystalline water(very organized with minimum oxygen) <--- This is key. Yes other crystals have differing amounts of water in them and yes they vary on the crystallization(organization) of the water but all crystals use water to some degree. It is how crystals refract light and it is how they desiccate things (salts). Salts are merely water crystals that the water has dried up from. All crystals are formed in water. What happens to them afterwards and what their components are dictates their properties. Water is also a very good medium to store [color=rgb(0, 0, 255) !important]natural energy[/color]. This energy was termed Radiant energy for lack of a better word and only describes the action of the energy, not it's true name.
I'm trying to see what else could take the place of epson salts.There are two isomers of epson salts(magnesium sulfate).
I need to spend time on studying that.Thanks to all for your comments.triffid
triffid
Magnesium chloride, oxide, gluconate, malate, orotate and citrate are all used as oral magnesium supplements. Oral magnesium supplements have been claimed to be therapeutic for some individuals who suffer from Restless Leg Syndrome (RLS).[citation needed][/li]
[li]Magnesium borate, magnesium salicylate, and magnesium sulfate are all used as antiseptics.[/li]
[li]
[/size]
The above compounds are food grade.I thought it important for now to stay with food grade chemicals since we are buying everything food grade except for the different metals used for electrodes.triffid
triffid
triffid
Sorry guys I found out today that I was not using my voltmeter properly.OL means over the limit.I was using only a 2 volt setting.OL meant I had to switch to a higher range like 20 volts.Once I switched to 20 volts I got 2.68 volts one time.
