Ibpointless2 Crystal Cells
triffid
Just reporting some results.At about 36 hours the morton salt/salt cell sub has dropped to less than 1/10 volt.With pressure it will pop back up to .25 volts.The cell with boric acid is holding at .47 volts.The aspirin cell is holding at .57 volts(recall that its max was .60 volts).Using a pair of pliers I crushed the 325 mg (one whole tablet) into the cell without mixing.Its generic aspirin.$1.00 per bottle of 175 tablets.Maybe from family dollar?My led is still burning but very dimly.I know aspirin has a lot of fillers in it.I need to test the aspirin more.Make more cells with it.triffid
triffid
Has anyone tried dripping wax on these cells?To keep water from them?I know they have been encased in plastic(too much money for me right now).I have seen many candles at garage sales.triffid
triffid
This man taught me to use whatever is at hand.   http://en.wikipedia.org/wiki/George_Washington_Carver  There is a story I read about him years ago.That he had been hired to teach chemistry at a black school.There was no equipment and no money for it.So he took the whole class to the dump to pick up bottles and jars.Brought them back to the school to be cleaned up and cut up into useable laboratory equipment.He said to make do with what you have.triffid
ibpointless2
Quote from: triffid on February 10, 2012, 01:06:52 AM
Yes I've seen people use Wax to cover their cells, it works great. Marcus Reid does this with his cells.
ibpointless2
Phi,
I never had much luck with Elmer's wood glue/putty. I've found it best to sue Elmer's Glue-all. Just using Salt sub by itself won't have the cell lasting long, in about a week it will drop off in voltage as the cell dries out. I also like to use folded up paper to place my cells on, not only is it cheap but it helps to wick away the water so the cell dries faster. Your on the right track, next you should try to make a glue cell with only Epsom salt in it. After that make a cell with Elmer's glue all, salt sub, and Epsom salt.
