Ibpointless2 Crystal Cells
triffid
Reading .8 volts a few minutes later.I had it up to over a volt when it was hotter.Will report on it tomorrow also.triffid
Good work PC,lots of action is good.I gonna build a joule thief at some point.
Since diodes eat up .7 volts and these cells act as diodes maybe???The diode action can be stopped somehow?
triffid
I heated up another tin can lid/mg cell and got .75 volts back.Thinking that I could do better I heated up the same cell again (it had been reading.9 volts before it dropped).It appears I burned the cell too much.I get nothing now.triffid
PhiChaser
@ triffid:
Nice! I've noticed that heat brings the voltage up too. I'd imagine in a low-humidity environment a lot of these cells would perform more consistantly. If it was a hot desert they would probably work even better? Do you know if anyone has tried silica (or even regular) sand in their electrolyte mix?
Happy experimenting,
PC
triffid
Those two cells I could put on a hotplate the others are in cardboard boxes or on cardboard.Heat drives off water and puts space back between the casimir plates recharging them to run a while longer.Maybe these glue cells work for a little while until the casimir plates come in contact with each other.Then the voltages drop to zero finally.Being in a hot car in the summertime could keep them humming?Just thinking out loud here.It seems like to me that as heat increases these cells become more efficient then the plates are vibrating farther and further apart.Maybe its not electricity that should be pumped into these cells but heat?Maybe the cells should be made in a hotter environment like an oven?Maybe why johns stove top cells work better and longer than glue cells?Glue cells would work better in a hot car in the summertime I bet.triffid
triffid
PC,NickZ has used sand in his cells.I heard today that silica has magnetic properties.I don't know what they are.Now that I know whats wrong with my cells now maybe I can redesign them?too bad I burned up the cell,it even turned brown on me.triffid
