Ibpointless2 Crystal Cells
0 Members and 18 Guests are viewing this topic.
PhiChaser
@ IB: I've been using pultruded carbon rod since I started. :) Awesome that you got over the 2 volt 'barrier', congrats! Aluminum can sit in regular water without the corrosion you get when using (untreated) Mg in the same fashion. (You won't see those kinds of results using aluminum though...)
I've been focusing my experiments on those two materials as electrodes because of this. I'm pretty sure the carbon rods I'm using won't corrode no matter what electrolyte I stick them into, but we will see in six months or so eh?
@ NickZ and Jbignes5: Polarization of the planes. Nice. The light tug of gravity statement was well put too! ;) So the 'medium' is tiny perfect squares that are really perfect circles... Is that fairly close?
I made a couple more cells yesterday and cleaned out my spice cabinet to get a few empty containers for more cells. My alum should be here any day... :)
Got another battery for my tester and a spare. :)
Anyhow, happy experimenting everyone! Congrats again IB!!
PC
NickZ
   Guys:
   I believe the polarization process to be an important point, although not well understood.  As people still talk about the "speed of light", as if light were traveling, which is false. The polarization rate of light is the speed at which light is observed going from one place to another, but with no physical movement actually involved. Just like a radio signal is not actually "traveling" from the station to a radio receiver, but is also "moving" by a polarization process at a certain rate, speed and frequency  which is also dependent on the medium that it "travels" through.
  Aether is not dependent of physical matter to exist, it is its own story by itself, and is the source which creates the physical worlds, by its own rules that it function by.
  Everything comes from the Aether, which is the rare-field solution of space. So, this is what we need to directly tap into, or harvest energy from.
    Light is an energy,  but as a non corporeal substance is not the same as anything in physical form. Nor do we really know what light really is, or how to produce, manufacture, or create it from the surrounding ambient. Other than by moving magnets past coils as in electrical generators systems (Tesla's ideas), and solar cells.
But, it is the solar cells as an analogy that uses the semiconductor system to produce electricity from so called sunlight, and in a similar manor it may be possibly the use of semiconductor system to produce, or convert, or tap electricity directly from the lattice,  without having to use "sunlight" at all.
   There is no light or heat in deep outer space, it is dark and cold as hell. Well, you know what I mean.
  Solar cells on space craft are limited to working only where there is light available, like on our space stations in close earth orbits, or on Mars, etz...  Or such as where a planets photosphere will allow them to function.  Light is produced or manufactured, by each planet, and is not send or received or reflected by the Sun, moon, or stars any other thing is space.  Because of the way that polarization works, it MAY be possible to "travel" through space, without actually traveling, such as from point A to point B.  Or we would never get there, even to the next closest star, as we don't live that long. Yet it may be possible to get to anywhere, or communitate with the rest of the worlds, much quicker than by shooting bulky rockets that need to carry heavy fuels through space.
  Ok, back to my cells.
b_rads
 8)  IB - Cool vid with the rock - Tell us more.
:)  NickZ - Hang in there dude, you are a valuable contributor and give us all inspiration.
New vid you might want to see,
http://www.youtube.com/watch?v=F0ypbO2eX1k
Brad
ibpointless2
Quote from: PhiChaser on February 28, 2012, 09:14:30 AM
PC
Thank you!
No need to worry about your carbon rods, the only way I know carbon to corrode is by extreme heat (thousands of degree's). Carbon will work great.  :)
ibpointless2
Quote from: b_rads on February 28, 2012, 11:28:42 AM
Brad
The rock crystal that I used to get the two volts and I showed in my latest videos is called Hematite. [size=78%]http://en.wikipedia.org/wiki/Hematite[/size]
It is basically iron-oxide, and its mined as the main ore for iron. The reason why I used it as a electrode was that its already be exposed to water and the environment so I don't need to worry about it corroding. You won't find the metals we use in our cells laying around, they're usually rusted or have a oxide layer on them and they must be heated up to remove the oxide layer and that leaves you with the plain metal. Hematite is heated up and the oxygen is removed and your left with iron/steel. Iron will always want to go back to hematite so why not just use hematite, nature's electrode? Hematite will always want to be the positive electrode so that means carbon, copper, and titanium will be the negative electrode and since most of these are corrosion resistant we can have electrodes that will out live us. So now it doesn't matter what crystal solution you use (to a certain degree). There is other ore's out their we can use too!
Here is where i bought my hematite, they gave me a extra gift of some more crystals too.  [size=78%]http://www.ebay.com/itm/180629943479[/size]
