Ibpointless2 Crystal Cells
triffid
ibpointless2
Quote from: triffid on March 10, 2012, 06:23:14 PM
I got more supplies today.Walmart sells 7.625oz of emlers glue all for $2.48 each I got two more bottles. Went to a hardware store picked up a box of copper plated nails small size (weather strip nails)3/4x 17 1.5 oz for $1.89.Maybe 100 count?Enough to do copper oxide experiments with.Both red and black copper oxides.Then bought 20 feet of 18 gauge parallel speaker wire 50 volt max for $3.98.Appears to be copper and aluminium braided wire. Then my brother gave some scrap copper and steel wires to make thermocouples.I think too I figured out how to hook up my cells in the panels without using the heavy wires from radio shack.My vitamin C panel I sealed up two weeks ago with wax I tested the back 6 cells hooked up in series gave me today 6.2 volts and .00062 amps  3.8 milliwatts.
I was looking at white out today they had it for a dollar today at walmart .I did not buy it.But I think I figured out how to protect the magnesium strips anyway.Mix up a batch of elmers glue_all and morton salt sub coat the mag strips with it 24 hours before use.In my vineagar cells.triffid
Copper plated nails? I never thought they made that? what section of a hardware store would that be in, I've never seen them with the other nails in the nails section at Lowe's before. Thanks!
ibpointless2
Here is something interesting to read. http://www.cheniere.org/techpapers/Final%20Secret%209%20Feb%201993/indexold.html
It talks about Tom Bearden and how you use voltage only and no amps to get free energy. Don't destroy the dipole.
PhiChaser
Evening all!
Finally got my alum today and made two cells with it after crushing and mixing with equal parts epsom salt (and a measure of Durham's of course ;) ). The three cells I made earlier used aspirin and are still (surprisingly) soft. Anyways, I found that the cheap-o ice cube trays cut easily with a decent pair of scissors which makes it easy to cut the 'cells' away as needed. 28 plastic cell 'trays' for a dollar isn't too bad...
Happy experimenting,
PC
ibpointless2
Quote from: PhiChaser on March 10, 2012, 10:41:00 PM
Evening all!
PC
Speaking of ice. I use to put some of my cells in the freezer to see what would happen and how would they respond to the cold. You could give the freezer experiment a try? I even made cells that were ice cubes with salts and such in them, it was very interesting.  :)
Just watch out sometimes the cells will expand or pop.
